coil pack question..
I got into my car tonight and when I started it it ran like it was on three cylinders, and the engine light was blinking. Having read here I knew it was the coilpack so I called road side assistance and they sent a tow truck. I had to start the car again to get it out of the parking garage so the truck could get it on the flat bed, and when I started it, the engine light wasn't on anad the car did not shack like it did previously. Is this common among coilpack problems? could it be something else?
No it's not common but it does sound like a coilpack. Once the dealer collects VAG tool data from
your car, they'll be able to tell. Would you please help our cause and fill out this survey ...
IGNITION COIL (coilpack) FAILURE SURVEY:
Just copy this survey, paste it into a new message box, and then,
place your cursor into each appropriate field and type in your response.
For instance, if this is your 2nd coil failure, your response to (5) might look like this:
EXAMPLE: (5) 1st __ B ___ 2nd __ C ___ 3rd _____ 4th _____ WEATHER ... Was the weather:
A ... Hot
B ... Mild
C ... Cold - Above Freezing
D ... Cold - Below Freezing
5a .. Do you have any other comments regarding the weather (snow, rain, sleet, etc):
_____2nd failure on a miserable day - Raining Hard - 39 degrees - Remote road - Out of cell phone range _____
SURVEY:
(1) CAR ... Describe your car:
Make _______
Model ______
Year _______
Engine type _______
Auto/Manual _______
FWD/AWD _______
(2) _____ NUMBER OF FAILURES ... Is this survey for your:
A ... 1st. Coil failure
B ... 2nd. Coil failure
C ... 3rd. Coil failure
D ... 4th. Coil failure
SYMPTOMS ... Check all that apply:
A ___ Shaking
B ___ Vibration
C ___ Rough Idle
D ___ Flashing Engine Warning Light
E ___ Steady Engine Warning Light
F ___ Minor loss of power while driving
G ___ Moderate loss of power whild driving
H ___ Major loss of power while driving
I ___ Total loss of power while driving
J ___ Could not keep the engine running
K ___ Didn't try to drive it
3a .. Do you have any other comments regarding the symptoms you experienced:
_______________________________
(4) 1st _____ 2nd _____ 3rd _____ 4th _____ WHEN FIRST NOTICED ... Did you first notice the problem:
A ... Upon starting your car
B ... After starting your car but before driving away
C ... Within 5 minutes of starting your car and driving away
D ... On the road - Inconvenience but not hazardous
E ... On the road - Hazardous situation - Traffic
F ... On the road - Hazardous situation - Weather
G ... On the road - Hazardous situation - Bad place to be stranded
4a .. Do you have any additional comments regarding the above:
(5) 1st _____ 2nd _____ 3rd _____ 4th _____ WEATHER ... Was the weather:
A ... Hot (85 degrees or higher)
B ... Mild (between 50 and 85 degrees)
C ... Cold - Above Freezing (between 32 and 50 degrees)
D ... Cold - Below Freezing (below 32 degrees)
________________________________
(6) 1st _____ 2nd _____ 3rd _____ 4th _____ AFTER THE FAILURE OCCURRED ... Once you noticed this problem
with your car what did you do:
A ... Turned off the ignition ... Had it flatbedded to the dealer
B ... Pulled to the side of the road ... had it flatbedded to the dealer
C ... Drove to a safe parking spot ... Had it flatbedded to the dealer
D ... Drove until you felt you were a traffic hazard and concerned for your safety ... Have it flatbedded to the dealer
E ... Drove until additional symptoms made you too concerned to drive further ... Had it flatbedded to the dealer
F ... Drove home ... Had it flatbedded to the dealer
G ... Drove directly to the dealer
6a .. Any other comments regarding the above:
_______________________________________
(7) _____ DRIVING STYLE ... Is your driving style typically:
A ... Gentle
B ... Moderate
C ... Moderate and sometimes aggressive
D ... Aggressive and sometimes moderate
E ... Aggressive
(8) _____, _____ DEALER RESPONSES (select 2) ... What did your dealer tell you when the car was brought in:
A .. Car ready .. Or ... Will be ready within one day.
B ... Parts are on order. One week estimate.
C ... Parts are on order. Two week estimate.
D ... Parts are on order. Three week estimate.
E ... Parts are on order. Estimate more than 3 weeks.
F ... Parts are on order. No idea of when they'll be in.
G ... Transportation, if needed, was provided for.
H ... Transportation, although needed, was not provided for.
J ... Comments _________________________
(9) 1st _____ 2nd _____ 3rd _____ 4th _____ COIL REPLACEMENT ... If your engine is a 1.8T, Did the dealer replace
your coil with the latest revision coil (Part # 06B-905-115-J for 1.8T -or- 06C-905-115-E for 3.0):
A ... Yes
B ... No
C ... Don't know
(10) 1st _____ 2nd _____ 3rd _____ 4th _____ 'ALL' COIL REPLACEMENT ... Did the dealer replace 'all' your coils with
the latest revision ignition coils?:
A ... Yes
B ... No
C ... Don't know
(11) - LOCATION ... Geographically, where did the failure occur (Closest major city and State or Province):
1st _______________________________________
2nd _______________________________________
3rd _______________________________________
4th _______________________________________
(12) - MILEAGE ... What was the mileage on your car when your coil failure occurred.
(13) - WHEN ... In what 'month' and 'year' did this failure occur:
(14) - CAR BUILD DATE ... When was your car built (month/year) ... (Look inside your driver door pillar for build date).
Write the date or write in your purchase date with an asterisk.
___________________________________________
(15) ______ DISRUPTION ... How serious was the effect of this problem on your planned activities ...
A ... Negligable .. Comments __________________________
B ... Minor .. Comments ______________________________
C ... Significant .. Comments __________________________
A ... Major .. Comments ______________________________
(16) - VENTING AND CUSSING ... Add any comments below that you'd like to share:
______________________________________________
You can do even more by using the following:
Here's the AudiTalk email address:
auditalk@audi.com
Here's the NHTSA link:
A ... Hot
B ... Mild
SURVEY:
Make _______
Model ______
Year _______
Engine type _______
Auto/Manual _______
FWD/AWD _______
A ___ Shaking
B ___ Vibration
C ___ Rough Idle
A ... Gentle
B ... Moderate
E ... Aggressive
A ... Yes
B ... No
C ... Don't know
A ... Yes
B ... No
C ... Don't know
auditalk@audi.com
uble1234
14
10-23-2020 08:07 PM
