Engine start blocked by immobilizer P1570
Could someone please help me understand where to look for the error:
Engine start blocked by immobolizer P1570.
Car does not start, no other error codes recorded. Ross tech of vag com says NOT really immobilizer if car does not start check something else.
Any ideas where to start? I will be disconnecting and reconnecting battery to see if that does anything but any other ideas welcomed.
Thanks
Thanks
Mine was a the key itself. In my case, I had a spare key and cost about $250, but if you no key, it has to be done by the dealer and is expensive...
Thanks again for the quick response.
So they all stopped working at once? If so, it is probably your Comfort Module. That is what reads the keys. Only way to know is to get a VAGCOM scanner and read the codes from the Comfort Module.
Ross tech says that if the car doesn't start then it must NOT be your immobilizer since I got an autoscan done I would imagine that would have found something in the comfort module so I am guessing it isn't that.
I am not even sure where to look here. What would I ask the dealer to do with the keys and what if it's not that
Sorry for all the questions..
Clear the code and try restarting it. if the code doesnt return thats not whats wrong. It should start, run for a few seconds, Die. Unless you tried that several times until it flooded out. Which if its cold outside thats possible. Also the yellow Immobilizer light would be blinking with the key on if it was seeing conflict with the immobilizer.
Lyleswk and Prospeeder, thanks for the info.
It turned out to be the starter. Starter was replaced and all is good.
On a side note, I am not sure if my audi model/year has the (blinking) yellow immobilizer light. Perhaps, this is because it isn't an immobilizer issue (despite the code).
Thanks again for all the help and Happy New Year.....
wilfred2k5
03-15-2005 11:45 AM
snowassociate
02-13-2005 07:06 AM
