HELP! Engine problems
Old Jun 17, 2004 | 02:45 PM
sp757's Avatar
New Member
Default HELP! Engine problems
Well,
I took off my Thermal exhaust on Monday. Ironically, ever since I removed the exhaust I heard a metallic sound that is hard to describe. I thought at first that the exhaust had a loose fitting.
I took the car in today to have the exhaust examined and to get an oil change.
The sound would not go away. They found nothing wrong with the exhaust. The sound can be heard with the car at idle or on the road.
Then later today, I lost all my boost. Yikes!
I can still here the turbo spool, not as well as normal, but I can still hear it.
I still have this metallic vibration sound.
My tuner can't see the car until Monday.
What do you guys think are the possibilities?
I have a K04 turbo with 1 bar software.
steve
Old Jun 17, 2004 | 03:16 PM
sleeperturbo b6's Avatar
New Member
Default you said metallic vibration sound, mm..does it sounds like a TDI? it could be the lifters from the
engine. is it a constant sound with constant speed of that sound?
you said you have it at idle, right?
how aobut when you rev your car..does it sounds faster or different compare to idle?
Old Jun 17, 2004 | 06:35 PM
sp757's Avatar
New Member
It's like loose washers dangling against each other_I have lost all boost
Old Jun 17, 2004 | 07:16 PM
sp757's Avatar
New Member
Default It is a metallic rattle, like something metal is loose_turbo spools but no boost
I used my Ross-tech VAG and NO fault codes.
Old Jun 17, 2004 | 07:23 PM
sp757's Avatar
New Member
Engine appears to run fine, no lights, no faults and no boost_car has less power than stock!
Old Jun 17, 2004 | 07:36 PM
sp757's Avatar
New Member
Now I'm thinking waste gate rod failure. Anyone experience this?
Tom10
Audi A3 / S3 / RS 3
10
Jul 8, 2018 09:30 AM
KekePerkele
Jul 19, 2016 10:53 AM
giuseppepat
Sep 2, 2015 02:47 AM
tvelasquez1
2.0T FSI Discussion
Sep 1, 2015 07:35 PM
ECS Tuning-Audi
Sep 1, 2015 08:27 AM
