home link...not working help
hey everyone i tryed to reprogram my garage door to my car and my home link isnt working was wondering if anyone else have had this problem when i go n press the button the red light does not light there never a flashing red light...i check the fuse n it was fine any advise where i should check next thanks
Was it working before? When I did mine I had to first let the Door Opener (the one in the Garage, not in the car) know I had a new remote.
There's usually a button somewhere on the back of the motor housing you have to press then go and press the one in the car. They need to "sync" up.
You can try clearing the memory for the buttons.
As am aside, you know the car either has to be running or the ignition in the Acc position to get the Home Link function to work. Even after it's programmed.
yea mine was working b4 n the past n my door opener isnt that type where u have to press the black botton on the back of the motor....the red led on the home link does not work at all wondering if that went bad...
