how to replace headlight
Bolts 1 & 2 are up on the top front edge of the headlamp housing and bolts 3 & 4 are behind the housing at the bottom. You'll need a socket extension to get to the ones at the bottom.
The connector is a major PITA. There is a clip that needs to be squeezed and after time it doesn't unclip very easily. Once it's unclipped you may need to wiggle the connector to get it loose.
Oh ya, on the passenger side you'll need to remove the air intake tubing but it only requires removing two small philips head screws. The driver's side should not have any obstructions at all. When putting the headlamps back in there are two small clips on the bottom of the housings that need to slide into place. It's very hard to do on your first try but take your time. You'll notice that the clips are in place if the gap between the bottom front edge of the headlamp housing and the bumper is small (less than 1/8")
<img src="http://pictureposter.audiworld.com/29024/headlamp.jpg">
