Just making sure. Oil change?
Old May 11, 2010 | 10:51 AM
Handsome_Rob's Avatar
Default Just making sure. Oil change?
How many L. or quartz of oil need for an oil change. i think 6 quarts. I have 2002 3.0 v6.
Old May 20, 2010 | 04:11 PM
Stephen Kormilo's Avatar
That's about right if you also change the filter. I always put about 5+ quarts in, check the level, run the engine for a while to check for leaks & then recheck the oil level, adding if necessary. I usually fill to about half way between the Full & Add marks. Remember, for an accurate reading, the oil should be checked while it is hot & several minutes after stopping the engine, to let the oil in the top end drain down to the sump. HTH
DennyDude
Audi 100 / A6 (C4 Platform)
17
Sep 11, 2008 04:48 AM
NewRacer
Audi A3 / S3 / RS 3
9
Jan 28, 2007 04:23 PM
sparkhill
RS4 (B7 Platform) Discussion
21
Aug 26, 2006 05:07 PM
b.searcy
Apr 3, 2006 11:50 PM
Black2001S4
Sep 4, 2003 08:54 AM
