More questions about Neuspeed Short Shifter problems...
I have a 2003 1.8 and installed the shifter about 2-3 weeks ago. Couple of days ago it started to get really sloppy. I went in and re-greased and tightened everything. That didn't work. I am having a lot of play in the shifter, both right and left and up and down. Even while in gear. I ran out of things to check and try. How much play should there be? Is there something that could be wrong with the shift mech. already? PLEASE HELP!
Mine works nicely also, very notchy when cold, and a little notchy once warm...
but no symptoms of what you talk about. I would tear it apart again and make sure everything is tight. Sounds like the two hex bolts are a little loose.
Audi Other FS: 2007 Audi RS4 black/black CCW
ilikeit
01-09-2016 09:24 AM
saifxnyc
9
11-30-2015 12:32 PM
