Need some help with my 03 Avant. when I fill up.the auto shut off on the gas pump..
kicks in. It's done it twice in the last month. I eventually was able to fill up but only after rocking the car and dribbling gas into the tank.
It's as if there is a vapour lock in the fill tube. I hear a gurgling sound and the gas sitting in the fill pipe bubbles and recedes slowly down the pipe. I know I read something about a carbon canister and a system that recirculates gas vapors into the engine for pollution control.Someone had said it can get blocked or something.
Any thoughts or solutions?
Hugh
Hugh
Re: Need some help with my 03 Avant. when I fill up.the auto shut off on the gas pump..
I had this happen once, dealer suggested I try a different gas station. I have not had any problems since then.
Bob Petruska Did you get your gas filling problem fixed?..
I see you had it down to the Leak Detection Pump LDP Audi even has a Tech bulletin on it but I couldn't find and resolution to your problem.
Hugh
Hugh
Re: Bob Petruska Did you get your gas filling problem fixed?..
I determined it was the carbon canister. It's fairly easy to check it out and told the dealer to change it before they changed the tank. It was the carbon canister!
SimianSpeedster
TT (Mk3) Discussion
72
08-30-2019 08:25 PM
vansoffyomama
09-28-2015 04:38 PM
517
09-25-2015 05:24 AM
