Oil problem on 97 2.6 convertible
Hmmm? Mine does this all the time....
<center><img src="http://pictureposter.audiworld.com/6607/clarion1.jpg"></center><p>Did you recently change the oil?
Switch to a different weight of oil?
Correct filter?
Correct filter?
Re: Hmmm? Mine does this all the time....
Tx. The car was serviced 2000 miles ago with oil change and new filter - all within Audi specification on oil grade etc. It could be a faulty filter I suppose....How did you cure your oil guage problem??
What weight of oil was used? 5w-30? 10w-40? Synthetic?
Is the correct filter installed? Part number?
Oil, if it is a heavier weight, like 15w-50, will cause your oil pressure to read higher.
Also cold outside air temps will make oil pressure high, until the oil and engine reach normal operating temps.
Audi's generally run very high oil pressure. My oil pressure gauge is always pegged high, until engine is hot, and at idle.
Re: What weight of oil was used? 5w-30? 10w-40? Synthetic?
Tx for the advice. Had the problem diagnosed as a faulty meter following a pressure test. At least I don't have to look forward to exploding oil filters.
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
New Member Welcome Area
09-01-2015 01:29 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
