Is it possible to add steering wheel controls?
Yes and no... (more)
The steering column electronic systems control module has the pinouts for it whether you have the multifunction wheel or not. However, I think something goes between those little switch modules you have pictured and that control module, besides just the wiring. Look at the relevant pinouts in the control module:
C - Connector for multi-function steering wheel/Tiptronic/steering wheel heating
7 - Push-button "-"
8 - Multi-function steering wheel "+" - Power supply
9 - Multi-function steering wheel data
10 - Heater sensor/push-button "+"
11 - Multi-function steering wheel dimmer
12 - Tiptronic Ground (GND)
13 - Steering wheel heating "+"
14 - Steering wheel heating "-"
7 - Push-button "-"
Re: Is it possible to add steering wheel controls?
That's interesting, I didn't think you could retrofit the steering wheel. Do keep us posted with more info if this is possible and ofcourse the $ investment with install. Did you approach the dealer?
Certainly it sounds like a cool idea but I am pretty confident I won't "swerve" if I just reach out to the car stereo .
If it does involve swapping the entire steering wheel, it isn't worth it - the airbag would need to be swapped too (assuming you have the 3 spoke wheel now) and that's pricey. But, if you can infact just install the buttons on the 3-spoke via some makeshift means, then it would be very cool and shouldn't be too expensive.
mrprism133
09-07-2015 07:22 PM
carl viking
09-05-2015 05:31 AM
Curtisjh
09-04-2015 04:06 AM
stormchaser1967
09-02-2015 08:48 AM
