PRNDS fault
PRNDS fault
My 2004 Audi A4 Sline has thrown PRNDS fault with all the light flashing on dash,gear selector moves but won't engage. We have changed the selector module unit under gear lever and also had ECU checked and no faults found. Has anyone else had this or have any idea on where to look next.
Did you scan the ECU or the TCU? You need to scan the TCU (transmission control module). You can’t get to that module with a generic scanner. You would need a program like VCDS or OBDeleven.
I've been searching, and I wonder... does the ecu throw codes w/o turning the check engine light on?
Tiblet
11
02-22-2005 10:43 PM
nocondorfx
06-08-2002 01:36 PM
