problem starting
Your problem could easily be the fuel filter is jsut plugged up and/or your pump is weak and you have low fuel pressure.
I've noticed of late that alot of us (and I'm the poster boy here) tend to get lazy about maintenance because so many cars these days have 100,000 mile everything it seems...spark plugs, coolant intervals, etc. The A4 is NOT one of hese cars. Plugs should be changed every 40k or so, ditto the fuel filter and other maintenance items.
Start simple and make sure you replace regular stuff that wears out anyways...might fix your problem and save yourself expensive trips to the shop.
order it with your vin and it will come matched to your keys. Took 30min to install.
And no need to reprogram anything
