Replace bew front brake pads...
The orange (o) symbol light up with a short beep everytime I started the car... I guess it is time to replace the front pads...right? Do I need some special tool to do the job (DIY)? I have experiences with Japanese cars before but haven't try an Audi yet! Thanks for you input...
It's like every other car pretty much.
No special tools, but a $2 C clamp or something similar is good to have to compress the piston. I would also pick up a package of the dark green lube to put on the slider bolts. I forgot the size of the allen wrench you need for those. If you are changing the rotors, I think the carriers are held on by a 17mm. You may need a breaker to get those off if they've been on for a long time.
here are a few pics from my wheel bearing job, maybe they can help you...
after removing the wheel there are 2 bolts holding the caliper (sorry, can't remember the size). I used some loosening stuff and a breaker bar.
<img src="http://i132.photobucket.com/albums/q33/x1rider/frontbrake1.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/frontbrake2.jpg">
Pic of the caliper off.
<img src="http://i132.photobucket.com/albums/q33/x1rider/frontbrake3.jpg">
Pic with rotor off.
<img src="http://i132.photobucket.com/albums/q33/x1rider/frontbrake4.jpg">
I used the reset tool for the piston but like Shameless in Chicago mentioned, you could probably use a C-clamp. I know I shouldn't press on the pad directly but I was pressed for time.
<img src="http://i132.photobucket.com/albums/q33/x1rider/frontpistonreset.jpg">
I hope this helps.
Pic with rotor off.
I hope this helps.
Do Not use a c-clamp to compress the caliper, go to your local
autoparts store and either buy or rent the caliper tool. To buy its about 30 bucks, i think where i bought mine, you pay for it full price and they give you a full refun if you bring it back in a certain amount of time.
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
elem
09-02-2015 02:20 AM
