Tail light bulb replacement on 2002 A4 Avant
in the sedan you open the trunk and on the side there is a piece of the carpet
that is shaped like a circle you pop that open with a screwdriver and there is one screw in there...take it out and then you open the taillight like a door. there are two plastic "dowels" that hold the taillight tight on the outside just pivot it out.
From Bentley: See Pic. Screw is under round plug just inside rear door seal on the sides.
<center><img src="http://pictureposter.audiworld.com/98458/a94-0344.jpg"></center><p>
Re: Tail light bulb replacement on 2002 A4 Avant
Alright....what am I missing? I'm pretty technically savvy and mechanically inclined, but before I break something...
I have loosened the screw behind the little plug and then it gets to a point where it won't come out anymore and the tail light still won't budge. The screw just turns with some resistance but never comes all the way out. Is it not supposed to some all the way out or is it somehow stuck?????
Any help is appreciated.
Yes, remove the screw, use a magnet or a pickup grabber tool....m
Then, gently pivot the housing toward the outside, the rubber part will allow this, on the forward edge, there are two pins, lift the forward edge away from the body, then the housing will move to the rear. Next, gently push the tabs holding the lamp carrier and remove the carrier from the housing to access the bulbs.
Maybe this will help: (From Bentley)
<center><img src="http://pictureposter.audiworld.com/98458/a94-0346.t.jpg"></center><p>
Remove screw - 1 - .
Swivel rear light outwards, and at the same time disengage retaining pins from body.
Disconnect electrical connection at bulb carrier
Re: From Bentley: See Pic. Screw is under round plug just inside rear door seal on the sides.
Hey diagnosticator-
Do you still have this pic you could post up again? I am having a tough time replacing this bulb. The left front was actually easier!!!
Thanks
audesign
Thanks
audesign
imag1ne
A6 (C7 Platform) Discussion
09-28-2015 01:05 PM
ECS Tuning-Audi
09-10-2015 01:14 PM
