Thermostat 02 1.8t
Thermostat 02 1.8t
So i have replaced the thermostat one time already but I did not realize that they went out so fast... Three weeks to be exact. Is there a known problem with these thermo's?
Well for starters the way I tell if a thermostat is bad is when the motor is already hot i touch the upper and the lower radiator hoses at the same time and feel to see if there is a significant difference in temperature... Then if it is significant I take the thermo off and get water up to 200 degrees and see if it opens up. The difference between the upper and lower hoses was over 80 degrees by my laser thermometer...
Where did you get your replacement from?
:: www.ECStuning.com :: Now with EXTENDED Customer Service hours!! | FIND US ON FACEBOOK!!
Phone: 1.800.924.5172 - Sales: 8:30am to MIDNIGHT EST | Customer Service 8:30am - 8pm EST
Questions? PM us for a quick response! | Email: Pete@ecstuning.com
Hmm, what is the age/condition of your water pump? I'm about to tackle the timing belt et al. on mine and I'm trying to decide if I should throw in a new thermostat as well. This is on an '02 1.8T w/ 71K miles.
Also, I didn't know if you knew that we have TB kits put together that save you a bunch of money:
Timing belt kits
Thermostats
Just the answer I would expect to hear from a salesperson . Actually, that was exactly my thought process, I just haven't heard about many B6 thermostats failing. I am aware you all have the kit; in fact, I just installed the aero wiper kit I got from you yesterday and it works great.
And at least I told you they fail often
gh0st
12-27-2006 11:41 AM
AudiS4guy - NorCal
NorCal Discussion
02-09-2005 08:54 PM
Nvncibl
12v V6 Discussion
07-07-2004 03:10 PM
