what synthetic oil do you guys use in the summer
Old 05-05-2008, 06:45 AM
  #21
Audi Junkie's Avatar
It's the same additives as gas PCMOs, but just more of them.
Old 05-05-2008, 06:54 AM
  #22
Default Not in normal 30 weight oil, esp dino w/SM spec.What you guys want is a heavy "Euro" 30 like...
MaxLife Synth, Mobil 1 10w-30 Hi-Miles, WalMart SuperTech Synth (yes!) 10w-30 HM and German Syntec 0w-30 and Castrol GTX HM.
Brands don't matter as much as the product does, that is all brands seem to have a single unique product that is usefull. There is no such thing as "bad" oil (except unrated or lower than SL stuff).
Oil weight is very dependent on temp, so you gotta determine how far over/under the temp of +212f that oil visc is rated at on the label. Old lady's stock 150hp Passat could use thin 30 Mobil 1 Pennzoil Platinum etc. Put that in a modded K-04...it'll chew it down and heat it up to 1/2 the visc it should be. V6 engines burn a bit of oil, so thin stuff could be a problem there too. The basic rule w/any machine lube is to use the thinnest possible w/o excess wear. Euro specs of a 40 weight assume hi-speed extended driving. Under +212f oil temp, that 30 weight is thicker than a 40....see? Going into summer, I'd stick with 40 weight. Mobil 1 0w-40 being a thin 40 that will shear to a 30, that's all I'm saying about that....great winter oil.
Old 05-05-2008, 06:58 AM
  #23
Default Pretty decent result w/TDT in this Audi V8 lab report...
Mobil 1 TDT 5w-40, 6994 miles, 2002 Audi A8L
"This change was Mobil 1,Turbo Diesel Truck 5w-40. Results are the left-hand column of data. Note that the fuel dilution problem visible in the first analysis is gone. Wear, particularly per mile, is very low. I suppose the increased tin is still so low it does not mean anything - yes?
Previous change was Mobil 1, 0w-40, no analysis done.
The time before that was Audi dealer oil (looks like sheared or diluted 5w-30, probably not any 502-rated oil). This is in the right-hand column. Note the fuel dilution.
2002 Audi 4.2L A8L
Mobil 1 TDT 5w-40
Date: 4/30/2008
Comments (Blackstone Labs): This oil is working well for you. Wear looks good too, even though you ran this oil more than twice the miles of the last sample. Metals all match up well with universal averages, and you haven't yet found the ceiling on how long you can run the oil. Try 8000 miles.
MI/HR on Oil 6,994 3,000
MI/HR on Unit 57,331 43,000
Sample Date 04/17/08 08/14/06
Make Up Oil Added 0 qts 0 qts
ELEMENTS IN PARTS PER MILLION
ALUMINUM 5 4
CHROMIUM 0 0
IRON 10 8
COPPER 7 9
LEAD 0 0
TIN 3 0
MOLYBDENUM 19 22
NICKEL 0 0
MANGANESE 0 0
SILVER 0 0
TITANIUM 0 0
POTASSIUM 1 2
BORON 39 72
SILICON 7 9
SODIUM 2 1
CALCIUM 2338 1840
MAGNESIUM 396 20
PHOSPHORUS 1023 650
ZINC 1183 701
BARIUM 0 0
Values
Should Be*
SUS Viscosity @ 210°F 69.7 65-78 53.1
cSt Viscosity @ 100°C 12.88 11.6-15.3 8.20
Flashpoint in °F 385 >375 335
Fuel % <0.5 <2.0 1.5
Antifreeze % 0.0 0 0.0
Water % 0.0 0.0 0.0
Insolubles % 0.3 &lt;0.6 0.3"<ul><li><a href="http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&amp;Number=1140810&amp ;Board=3&amp;fpart=all&amp;gonew=1#UNREAD">http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&amp;Number=1140810&amp ;Board=3&amp;fpa
Old 05-05-2008, 06:59 AM
  #24
hehateme's Avatar
thanks man, great info
Old 05-05-2008, 07:33 AM
  #25
shaag81's Avatar
Default was the clear coolant res. stock on your car?
I want to get rid of the gray tank on mine.
Old 05-05-2008, 12:26 PM
  #26
Shameless in Chicago's Avatar
Whatever kind the technician puts in there is cool with me.
Old 05-05-2008, 02:42 PM
  #27
As tragic as Audi's oil/sludge issues have been, the"Approved"VW502 oils can't cut it in the new FSI
Old 05-05-2008, 03:04 PM
  #28
AudiWorld Expert
MikTip's Avatar
Yes
Old 05-05-2008, 03:29 PM
  #29
AudiWorld Expert
Merkin's Avatar
indeed, even TDT gets diluted by FSI in 3000 miles
Old 05-05-2008, 04:30 PM
  #30
heateris's Avatar
whatever i have. right now i'm using shell rotella 0w-40.
Quick Reply: what synthetic oil do you guys use in the summer
