When it rains it pours...another coil pack issue (info please)
I just played musical coil packs and found the one that needed to be replaced. I made the change and everything seemed fine. Now two days later it's the same problem again. Is it normal for the coil packs to go at the same time? Should I be replacing all of them at the same time or is this just a coincidence? Can this be a sign of another problem?
2nd...however, mine were kinda spaced out.
Cylinders 2 & 4 @ 43,000 miles
Cylinder 3 @ 53,000 miles
Cylinder 1 @ 80,000 miles
But once one goes, the others go at some point. Some sooner some later. As you can see, the first failure and last failure were almost 40,000 miles apart.
I had 3 fail, in a matter of three weeks, but the 4th one has been in there for 2 years.
i keep 2 spares in the car since then. so, i've saved myself from throwing out $30. FWIW.
PoisonBeef
09-04-2015 05:29 AM
stormchaser1967
09-02-2015 09:26 AM
Touge.ca
Canadian Discussion
09-02-2015 01:28 AM
