05.5 a4 2.0T ecm error connected to fog lights?
Hi how's it going I just recently traded my g35 for this Audi and the check engine light is on for ecu (P0601) and is also saying other codes like turbo under boost and a coolant issue was wondering if the ecu error is just the problem and putting out codes I really dont have? Also the previous owner has just recently put in aftermarket fog lights and had cut the wires and put then to the new ones, would this wiring cause my check engine light come on for my ecm?
You can use this for the codes... PlanetVAG.com - VAG Diagnostic Trouble Code (DTC) or OBDII Code Search
The P0601 is a pretty serious error if I am not mistaken as it could be indicating that someone played around with the ECM software. Or the ECM could be bad.
I agree fog light wiring issues will be extremely unlikely to generate anything related to engine operations (EFI software on the ECM). Perhaps the previous owner chipped the car and the tuner did not know what they were doing?
Cheers
Massboykie
Tusin
A4 (B7 Platform) Discussion
05-26-2009 09:37 PM
hawaiiallroad
Audi allroad
36
09-05-2006 07:37 PM
hawaiiallroad
11
09-04-2006 10:09 AM
hawaiiallroad
12
09-04-2006 02:11 AM
Flounderasu
06-22-2005 04:21 PM
