A4 2.0T SPORT MODE TRANSMISSION QUESTION
In "Drive" and accelerating conservatively, my 2006, A4 routinely shifts at 2,200 RPM. In sport mode, the trans never shifts under 3,200 RPM.
Are these the normal shift points under no load conditions?
Any way to change them using VAG Com?
That's what "sports" mode means...
...you keep the shift points higher. I manually never shift my car under 3,000 rpm under any condition anyways.
The worts thing that you can do for your engine is to undershift it all the time.
"D" is really programmed for fuel economy. "S" for "sport". If you want anything else, use Tip mode.
sport mode is supposed to shift later
Sport mode means you want to use more of the power band, hence, shift later. Why would you want to change that compared to simply driving in "D"?
Alpha6-27Tango(jeff)
07-18-2005 10:13 AM
BluHeaven
01-18-2005 07:06 PM
roadrunner13
07-25-2002 05:49 AM
