Found plastic key with SIM in 2006 Audi A4
probly the chip that goes in the key that allows u to start the car, without that chip the car wont start even if it is the correct key.
Im not sure if im correct but thats what id guess
Where exactly did you find this key...in a slot near the ignition switch column or in the dashboard or loose in the glove box? There are no references to it in the instructions...only the 4 keys: (2) Foldable Fob Keys, (1) Valet Key (can't open glovebox or trunk if they are secured), and (1) plastic emergency key (to gain entry into the vehicle) as stated earlier.
Having a plastic key with chip, but not cut would mean the car would start if anyone had a key "cut" to fit and turn the ignition switch ON. Might be a normal dealer item inadvertently left in the vehicle.
Maini
07-13-2008 02:57 PM
AaronG79
04-12-2002 04:25 PM
