Help with noise in Climate Control Console
I'm hearing a clunking noise from the climate control console periodically when it's set to auto. I guess the climate control is trying to stablize the temp and maybe that's why its' making the noise?
Is this normal?
Is this normal?
Re: Mine doesn't make that noise.
I don't think it's the compressor because I'm hearing it with the ECON mode on. I think that disables the compressor. It sounds like a vent opening and closing. Hard to explain
Automatic means it has a mind of its own
Climate control will make adjustments to airflow based on where it is in the control cycle. This means it will adjust dampers to control flow from the floor, the mid-level, side vents, and top vent. You are hearing the damper servomotors.
Cmmartin23
26
08-23-2016 04:44 PM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
Audi A8 2005 Audi A8L
Jan_PL_S6
12
11-27-2015 07:27 AM
stormchaser1967
09-02-2015 12:47 PM
stormchaser1967
09-02-2015 09:02 AM
