A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
How long should my first set of tires last?
Old Jun 5, 2007 | 08:04 AM
  #21
imageWIS's Avatar
New Member
$91 each from Tirerack...I got 2 for the front now and will replace the rear's in like 2 or 3 weeks
Old Jun 5, 2007 | 09:15 AM
  #22
Gorobei's Avatar
Okay, then tire pressure wasn't the culprit.
Old Jun 5, 2007 | 10:16 AM
  #23
98's Avatar
98
Member
Default I think it was these two turns that did it.
Traveling eastbound then drift around the bend west to eventually merge North
<a href="http://maps.google.com/maps?f=q&hl=en&q=santa+clara+ca&ie=UTF8&ll=37.3741 26,-121.964276&spn=0.002903,0.00471&t=k&z=18&om=1">The drifter</a>
From the North traveling south, right hand 90 followed by left hand 90 to eventually merge westbound
<a href="http://maps.google.com/maps?f=q&hl=en&q=santa+clara+ca&ie=UTF8&t=k&om=1&l l=37.375605,-121.967221&spn=0.002903,0.00471&z=18&iwloc=addr">C hicane</a>
A lot of times I would go home for lunch so I would hit them each twice a day.
Old Jun 5, 2007 | 06:57 PM
  #24
PhatAudi2T06's Avatar
New Member
Default No that diagram is well on point
The diagram is extreme but unless you hit certain points of a turn, like an on ramp, you will melt the tire away especially as we see warmer weather. I forgot what our tires are rated as far as heat but its not a lot.
Again look into a better street tire and you will see less of an effect.
Also PSi is kinda hard to rate, the door jam is noted for the avg driver and a certain weight. That might be too much, also when did you get that PSi rating when cold or hot? There is so many factors that go in...but
a) get street tires not all weather
b) rotate tires every 3k
c) fool with the psi till you get one thats good or ask around
Old Jun 6, 2007 | 07:19 AM
  #25
imageWIS's Avatar
New Member
I got the ASX's cus they are sport all-weather, plus it rains a lot here in SoFLA
Old Jun 6, 2007 | 07:59 PM
  #26
jtojeda's Avatar
New Member
Default Re: Which tires did your car come with?
52,000 miles on the Pirelli's. Switched to Yokohamas... cant remember the type off hand but they ruined the handling of the car by going to a 255/50 over the 245/50. Wifes car, tried to make it a bit "softer" but the handling seriously went to crap
Corgiman
Q7 MKII Discussion
23
Nov 26, 2018 01:28 PM
tpoltron
Q7 MK 1 Discussion
13
Oct 8, 2018 08:05 AM
awdinut
13
Jul 25, 2014 12:03 AM
gordydotcom
Wheels & Tires Discussion
Jun 22, 2012 08:10 AM
Duke_nc
Audi allroad
15
Aug 29, 2003 11:04 AM
