A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Keyless Entry Problems...
Old Mar 27, 2006 | 08:41 PM
Djca33's Avatar
New Member
Default Keyless Entry Problems...
Is anyone having any trouble with their keyless entry?? Apparently my key fob works when it decides to. Sometimes my doors will lock and unlock when I press the button and sometimes the trunk will pop open when prompted. When I press the buttons on BOTH key fobs, the keys light up, however, there are times where the car will not respond with the proper action.
HAs anyone else had this issue and know how to get it fixed or remedy it?? I got my car last March, so it's not old..but is it perhaps a battery issue within the key fobs??
Old Mar 27, 2006 | 08:59 PM
steveAZ's Avatar
Junior Member
Default There is a known TSB for this. Should not be an issue to get them replaced.
I'm was on my 4th keyfob, before they finally replaced my locking control unit. But typically its just a bad fob.
Old Mar 28, 2006 | 06:31 AM
kuthair's Avatar
How bout a picture of the new fob?
Old Mar 28, 2006 | 07:23 AM
kvanwagoner's Avatar
Junior Member
they look the same
Old Mar 28, 2006 | 07:28 AM
kuthair's Avatar
They look the same as B5/B6? I thought B7 had a new key fob?
Old Mar 28, 2006 | 08:27 AM
Joel Mundt's Avatar
25 Year Member
Default Yeah, apparently this is a VERY common problem...
...mine's starting to act up, too. Will get it replaced at the next oil change.
Regards,
Joel
'05.5 A4 2.0TQMSX
Old Mar 28, 2006 | 09:56 AM
Junior Member
b7 is new....i thought you meant the replacements we were getting we an even newer design
Old Mar 28, 2006 | 11:57 AM
SoCalB7's Avatar
New Member
Default Common problem, here's what to do
As noted, there is a Technical Service Bulletin issued for this item, so your dealer should be well aware of it. The issue is not with the batteries, the entire key fob needs to be replaced.
1) Call your dealer, notify them that you are having a problem with the fobs that will need replacement. You might want to have your VIN number available, just in case the dealer can't locate it.
2) Hurry up and wait. The new fobs need to be ordered from Audi, so you can expect a delay of up to a few weeks before they arrive at your service department. Each fob comes from Audi matched specifically to your car, so your dealer can't just go pull a generic one of the parts bin and get things started, the one that matches your car will need to be delivered to your dealer.
3) Go to the dealership. Once the fobs have arrived at the dealership, they need to be programmed. Bring ALL of your keys, including both fobs and the valet and emergency keys, just in case. The dealer will program the new fobs to match your car, a job that should take about an hour.
Notice that this should require only one trip to the dealership. Again, you need to plan ahead, as getting the fobs delivered could take awhile.
 Michael S. Palmer
Old Mar 28, 2006 | 01:34 PM
ChillyInPhilly's Avatar
Had mine replaced, and it's been fine ever since.
DDRRNN
Sep 11, 2017 10:28 AM
clean.
19
Aug 14, 2009 07:50 AM
NiceS4
Jul 22, 2006 08:00 AM
DalD
Feb 21, 2006 06:32 AM
Tanner
Canadian Discussion
Sep 9, 2005 05:34 AM
