A4 (B7 Platform) Discussion Discussion forum for the B7 Audi A4 produced from 2005-2008.5
Oil changes
Old Sep 11, 2005 | 01:16 PM
CSadler's Avatar
New Member
Default Oil changes
Ok, newbie here.. My current ride is a Black 05.5 2.0T MT6Q. Im used to doing things myself,so, I pose the question....Has anyone been able to change their own oil? Are there any tools available to do this? And last question, has there been any issues with substituting the 0w40 synthetic oil with Mobil 1 5w30 or 5w40 synthetic oil?
Old Sep 11, 2005 | 03:10 PM
rickolis's Avatar
Default free oil changes are included with warranty at 5k, 15, 25, 35, 45k
don't you have to have them do it in order to not void your warranty? at least that's my understanding....
Old Sep 12, 2005 | 07:40 AM
CSadler's Avatar
New Member
Default Re: free oil changes are included with warranty at 5k, 15, 25, 35, 45k
Yes, the oil changes are included in the price, but they want to charge if I come in early before the correct milage is up. I like to change every 3-4000 miles. Ive noticed the oil that the dealer uses is already dirty. It looks like it breaks down too quickly. I just had it changed 4k miles ago. The Mobil 1 synthetic I use to use in my truck lasted alot longer.
Old Sep 12, 2005 | 08:26 AM
cr8nA4's Avatar
Default It must have the VW 502 certification, Mobil 1 5W30/5W40 doesn't
I did non-free oil changes at mid points (7000-8000km) on my B6 1.8 using Mobil 1 5W40 that was readily available from Walmart.
When the sludge scare came out, the only Mobil 1 to meet the 502 spec was 0W40, which is really hard to find (I buy it from the distributor by the case).
Old Sep 12, 2005 | 10:00 AM
peta8368's Avatar
New Member
Default Re: Oil changes
The last time(and only time) i did it, i took off the sensor on the bottom of the oil pan first and drained from there, but there was still a lot of oil coming out of the filter casing(that part is just a twist off by hand). you MIGHT need to do both end(if so, you will need a 4mm hex bit to take off the sensor), i will find out for sure at the next oil change.
Of course, you will need a flat head screw driver to take off the bottom plastic covering as well.
Old Sep 13, 2005 | 02:54 AM
aretubj's Avatar
Default Re: It must have the VW 502 certification, Mobil 1 5W30/5W40 doesn't
I noticed the other day that Walmart carries the Castrol 0W40, which is what my dealer uses, only in bulk format, that has the 502 certification. But they do not have, nor does anyone, have a listing for the oil filter. I'm assuming that's a dealer item. I too am very fussy with oil changes, they must happen every, 5,000Km.
Old Sep 13, 2005 | 07:31 AM
Vic995's Avatar
Junior Member
Default Mobil 1 0w-40 can be purchased online here.
Shipping is $7.50, iirc, for any number of cases. buy at least 3 or 4 cases and you can recover the shipping cost by not having to pay sales tax (unless you're located in TX).<ul><li><a href="http://shop.store.yahoo.com/parkplacemotorcars/mob1trismoto.html">clicky</a></li></ul>
Old Sep 13, 2005 | 03:41 PM
bhvrdr's Avatar
You need to get the canister insert from the dealer and I would use M1 0w-40 as it is 503.01.
 Pouria Savadkouei
 Michael S. Palmer
Old Sep 13, 2005 | 03:54 PM
Aarononymous's Avatar
Default You need a 36mm socket (ebay) for the filter housing
...ideally you want the drain tube attachment for the housing, otherwise if you drop the filter cartrige housing it's gonna make a mess. But I don't think the drain tube is available.
balabee
Dec 26, 2015 08:23 AM
hardipk5
Oct 2, 2015 08:32 PM
beep-beep
Audi A3 / S3 / RS 3
Sep 24, 2015 02:25 PM
smallbizwhiz
S4 (B8 Platform) Discussion
Sep 24, 2015 11:31 AM
Cristone
Sep 24, 2015 08:11 AM
