2012/13 Models - Disabling turn indicator LED DRL cutoff..?
Hi there
It is nice coming back to this forum after a hiatus of 14 years (back in the day when it was Jason Teller's A4.org site. I recently trade in my 15 year old A4 (2.8 V6, 12 valve quattro) for the A4 allroad Premium plus with Navi , B&O with Advance key options. It has been fun experimenting the car and have been pleasantly surprised with the low end torque on that car.
The one minor annoyance is the way the LED Daytime Running Lights shuts off whenever the turn indicator light on the same side is switched on. It takes away from the unique image of the shape of the LED DRLs and to the novice it appears that LED is broken when the indicator is turned on. I understand that this was due to a US requirement that the turn indicator must be brighter than the DRLs . My observation indicates that the turn signals are very clear and bright and are not overshadowed by the DRLs.
The question out there to the forum is if anyone else finds this problematic and has found a way to disable that function (perhaps a change of a fuse..??) I have searched the forum for the same question but have not found similar posts
Thanks in advance
K-Man
Thanks in advance
K-Man
Although I don't have a B8 yet, I have been doing a bunch of research prior to purchasing a 2013 and have read about the attached:
http://www.audienthusiasts.com/VagComEXLight.html
The VAG Com is a cable that connects your car to a computer and allows you to change certain settings. The link has the specific one you are talking about as well as a few others related to exterior lighting. There are also other changes on the site. From what I've read so far, the B8 changes also apply to the B8.5 (2013) models.
If you post in your regional forum, you may be able to hook up with someone who has the cable to make the change for you.
Good luck.
Good luck.
Good luck.
Good luck.
Thank you very much for your response. I will certainly take your advise and check the regional forums
Thanks again...
Or you could use this locator:
http://forums.vwvortex.com/showthrea...-in-the-thread
Disabling LED DRL when indicator is turned on - it worked..!
Steamer,
Just wanted to let you know that your suggestion worked. I took the car to my local mechanic with VAG and he did it after talking to the Ross-Tech folks for a couple of hours ... I got charged 2 hours and it looks great... Check out the pic..
Thanks
K-Man
Thanks
K-Man
Or try asking their local dealer service advisor to do it and pay the 1-2 hours of their time. It is about building long-term relationships.
Or hook up with members to help out. Either way, it looks like you got it.
Cheers
StraySheep
TT (Mk3) Discussion
26
01-04-2023 03:04 AM
phanatic
A4 (B8 Platform) Discussion
10-30-2008 06:11 AM
