drinking too much oil
Do you do your own oil changes? The crush washer used on the drain plug should be replaced with every oil change if you drain the oil using the drain plug. Otherwise it could cause a slow leak resulting in having to constantly top it off. If you use an oil extractor you'll never have to remove the drain plug.
You are experiencing the common oil problem caused by defective piston/rings . The only correction is to replace the pistons and rings.
If you're beyond the oil consumption extended warranty, it's probably best to move on to a new car and dump this one on an unsuspecting rube.
