Brake pads
Brake pads
Not sure if brake pads worn light is optional feature in Audi A4 B8!! So is it fine to drive for another 1-2K kms with these brake pads?
Front wheel left side(Driver side)
Front wheel right side
Back wheel left side
Hard to say. The spec is once the wear pad, backing plate, and dampening pad thickness is 10mm front / 7mm rear, then it's time to replace the pads. That's from the brake system repair manual. The maintenance procedures guide says 7mm front / 7mm rear. I use 10mm front for my front pad replacement decisions.
On my last service - My mechanic advised to check the front brake pads after 5000-7000 KMs and I am on 3800 KMs now. So probably, will drive another 1000-1300 KMs and change it.
DutchDoofus
9
09-05-2008 11:28 AM
XCCESS
9
01-12-2007 01:17 PM
Zzak
06-16-2004 06:47 AM
JBM
02-09-2004 04:14 PM
