Brakes sticking have already changed caliper and hoses
Is this one caliper or is it all 4 calipers. Is it front or is it back. Is it an E-brake issue or just normal brakes. Are there and stored codes. Has the brake fluid been changed lately. Have you changed all 4 brake hoses. Need more info. When did this start to happen . Was anything done to the car before or when this happened.
A4 brakes sticking
Hi thanks for reply. Only sticking on front left .no faults or lights on. Only started to happen when changed front pads. Handbrake and other wheels all seem fine
OK so what do you mean by "sticking". What was wrong with the old caliper. With the wheel off of the ground can you turn the wheel easily . Did you replace the rotors. Are the caliper slides lubricated and the pins or clips in correctly. Have you tried another set of brake pads. Does the car pull to one side when you stop. Does the car pull to one side while driving. How are the tires and has the front end been aligned lately.
