Carista for iPhone is now available: Audi coding for your B8 through an app
Hi all,
I'm happy to announce that we've just released Carista for iOS! I know a lot of you with iPhones and iPads have been waiting for this release, so go get it! Here's the link to the Apple App Store: https://itunes.apple.com/app/id954363569
The app is also available for Android, in case you're wondering
In order to use the app, you need a WiFi ELM327 device, which you can get from Amazon or other retailers. We've provided some sample links here: Hardware | Carista OBD2 - Vehicle Diagnostics and Customization
We're constantly adding new customizable settings for the Audi A4 B8 and the available ones differ based on the exact year, model, options, market, etc.; that said, here's a sample list of things that Carista can configure for a specific 2013 Audi A4 (UK model):
Doors / Windows / Remote:
Auto-lock doors when moving
YES / NO
Auto-unlock doors when key is taken out of ignition
YES / NO
Auto-lock trunk when moving
YES / NO
Beep when alarm is armed
YES / NO
Unlock doors via remote
DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND / ALL DOORS ON 1ST PRESS
Unlock doors via smart key (door handle button)
Enable settings for opening/closing windows and sunroof
YES / NO
Open/close windows and sunroof via long-press on remote
YES / NO
Close windows via long-press on remote
YES / NO
Open windows via long-press on remote
YES / NO
Close sunroof via long-press on remote
YES / NO
Open sunroof via long-press on remote
YES / NO
Sunroof action when opening via remote
SLIDE / TILT
Open/close only driver's window via remote or key
YES / NO
Open/close windows and sunroof via smart key
YES / NO
Close windows via smart key
YES / NO
Close sunroof via smart key
YES / NO
Open/close windows and sunroof by holding key in door lock
YES / NO
Open windows by holding key in door lock
YES / NO
Open sunroof by holding key in door lock
YES / NO
Close windows by holding key in door lock
YES / NO
Close sunroof by holding key in door lock
YES / NO
Close convertible roof via long-press on remote
YES / NO
Close convertible roof by holding key in door lock
YES / NO
Close convertible roof via smart key
YES / NO
Open convertible roof via long-press on remote
YES / NO
Open convertible roof by holding key in door lock
YES / NO
Blink turn signals when done closing windows via remote
YES / NO
Enable remote control when vehicle is running and in gear
YES / NO
Instruments / Display / Dings:
Display warning about using navigation when moving
YES / NO
Gauge needle sweep at startup
YES / NO
Gauge needles lit even when headlights are off
YES / NO
Gauge scales lit even when headlights are off
YES / NO
Seat belt warning
DISABLED / US/CANADA STYLE / EURO STYLE 1 / EURO STYLE 2 / EURO STYLE 3
Navigation disc eject button
ENABLED / DISABLED
Lights:
Allow configuring daytime running lights via dash display
YES / NO
Use front LED lights as daytime running lights
YES / NO
Use fog lights as daytime running lights
YES / NO
Use high beams as daytime running lights
YES / NO
Use tail lights as daytime running lights
YES / NO
Use side marker lights as daytime running lights
YES / NO
Use low beams as daytime running lights
YES / NO
Dim daytime running lights when ignition and parking lights are both on
YES / NO
Turn off daytime running lights ("wink") when turn signal is on
YES / NO
Coming-home lights
ENABLED / DISABLED
Leaving-home lights
ENABLED / DISABLED
Use fog lights as coming-home lights
YES / NO
Use low beams as coming-home lights
YES / NO
Coming-home lights duration
10 SECONDS / 20 SECONDS / 30 SECONDS / 40 SECONDS / 50 SECONDS / 60 SECONDS
Ambient light threshold for leaving-home lights
0 / 1 / 2 / 3 / 4 / 5 / 6 / 7
Turn off front fog lights when high beams are on
YES / NO
Turn off rear fog lights when high beams are on
YES / NO
Flash brake lights in emergency stopping
YES / NO
Flash hazard lights in emergency stopping
YES / NO
Turn on side marker lights with headlights (US models only)
YES / NO
"Euro" parking lights when ignition off, turn signal on
YES / NO
Other:
Lower passenger-side mirror when in reverse gear (may need memory seats)
YES / NO
Remember position when lowering passenger-side mirror in reverse gear
YES / NO
Auto-enable rear wiper when front wipers on and reverse gear engaged
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
SLIDE / TILT
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
Seat belt warning
ENABLED / DISABLED
Lights:
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
Coming-home lights
ENABLED / DISABLED
Leaving-home lights
ENABLED / DISABLED
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
YES / NO
Other:
YES / NO
YES / NO
YES / NO
Fantastic this has finally become official! So for $19.99 we download the Pro App in order to make coding changes, then another $16.99-$29.99 for the ELM327 connector. All in that's ~$50.00!
I just downloaded the App and need to pick up a WIFI ELM327. What's the advantage with the more expensive version you listed, looks like it's faster?
P.S. Do you also have a BMW E92 (judging from your user name)? I'm asking because we're currently testing BMW functionality in the app and we're looking for beta testers. I'll let you use the app for free if you agree to test on the BMW. Thanks in advance.
The main advantage of the iKKEGOL one is that it has a power button and a proper sleep mode - so it doesn't drain the battery if left plugged in. Performance-wise, I think they're all pretty much the same.
Got it! Yes, I do have a 2013 E92 M3. I'd be happy to test it out, just let me know what to do. Do I need a new adapter or will the iKKegol work for the Audi and the M3? I do have some expereince in my younger days with beta testing on Nissans using UpRev's software if that helps.
And... I'm not a hippie or a hipster if that makes a difference.
P.S. being a hipster not required.
But most likely, next week we'll have a beta with more stuff in it. Thanks for your patience. Please sign up here to be notified of the new betas and releases: Carista for iOS (iPhone / iPad / iPod touch) | Carista OBD2 - Vehicle Diagnostics and Customization
(or if you do have Carista installed, you can just connect to your car and see what's available, without paying)
Hi guys, just wanted to let you know that we have a Black Friday / Cyber Monday deal on the Carista OBD2 adapter - get 25% off today through Monday! https://goo.gl/Y0CklK
treoless
Q5/SQ5 MKII Discussion
01-09-2019 11:31 AM
DSM6
A4 (B9 Platform) Discussion
03-18-2017 11:35 AM
