Engine Death? 2.0 TFSI 2009 A4 B8
Hi guys,
Hoping someone has a good ear!....
The below changed as engine was just f***ed
Timing chain, all guides and tensionors changed
Water pump changed
cam shaft bridge changed (Old screen found intact in oil sump filter so it hasn't caused any damage)
both intake and outlet cams changed
valves re-seated
Referbed block with new rings and existing pistons (were in good condition)
Recently had a new PVC valve (around a year ago)
The little thing that goes into the camshaft bridge and the inlet cam (I forget what its called)
Standard new seals and gaskets
Is my engine dead?!
Water pump changed
valves re-seated
Is my engine dead?!
It is clearly having a misfire, you would need to scan the car and get the codes to help narrow it down further. As for the high pitched noise, it honestly sounds like a vacuum leak, which can also cause a misfire, IIRC on these engines.
Just thought i'd provide an update for anyone facing the same issue
It was the crankshaft rattling around as the thrust bearing had completely been shaved away
New block finally in, going to try today!
inaudiwetrust
A4 (B8 Platform) Discussion
02-25-2016 09:00 AM
Pete.S
S4 (B8 Platform) Discussion
01-13-2010 04:16 AM
