SET Button Functionality
I recently got my first car (2014 Audi A4 2.0Quattro) and have some trouble understanding the regular checks I should be doing to make sure I am not damaging the car in anyway.
I saw this unclear section in the owner's manual that "SET" button does Auto-Check sequence. I tried it on car, it shows series of warning symbols: Red coloured symbols- Battery, Engine Oil Pressure, Engine Cooling System, Km/h and Yellow coloured symbols - Worn Break Pads, Windshield washer fluid level, Defective light bulb, Engine Oil Level, Tank System. Does it mean car currently has issues with all these systems? or it is just doing a check on all of these?
The engine oil menu in MMI showing "OK" and I recently filled windshield washer fluid. I recently had a dead battery so I had to jump start the vehicle, also the engine coolant is below min level, so battery and engine cooling system warning symbols make sense, but not sure why other symbols are shown.
Also, after jump starting the car, my instrumental panel is not showing any warning symbols now, probably because there is not enough battery? How long we should drive to recharge the battery completely?
I know these are lot of questions, if you recommend showing the car to an Audi dealer, please do let me know. Just trying to understand if these are simple things that can be addressed from community members like you!
Regards,
Siva
You do not need the diagnostic software unless you are up to the task of understanding
the processes and this is complex, takes lots of time to learn.
Good luck with your new car.!
