A4 (B8 Platform) Discussion Discussion forum for the B8 Audi A4 produced from 2008.5
Steering rack problem
Old Aug 17, 2023 | 07:01 AM
Nikola998's Avatar
Default Steering rack problem
Hi everyone.
I have Audi a4 B8.5 2012
When turning the steering wheel in place, regardless of whether the car is on or off, a screeching sound is made.
I think that can be steering rack, so i asked a few services but they told me that can’t be repaired just replace with new one but the price is unbelievable 1000e+
Is anyone know how to slove that?
Old Aug 17, 2023 | 10:00 AM
SMac770's Avatar
Community Builder
Community Influencer
You need to find out what the sound is. If you lift the front end and turn the rack, do you still hear the noise? If you unbolt the tie rod ends from the wheel bearing housings, do you still hear the noise when you turn the wheel? You might have a ball joint worn out. One video demonstrating creaking from ball joints: youtu.be/aHLiMs5N0tg . My front right makes a noise similar to the video; I suspect it's the ball joint the lower straight arm mounts onto.
But you should work on isolating the source of the noise first.
Old Aug 18, 2023 | 01:33 AM
Nikola998's Avatar
Thanks for your reply.
The sound is not the same as in the video.
I drove the car in deeper water and after that it started to hear a scratching sound, as if there is not enough lubrication and it is always heard when the car is stationary or when parking. I read that it is mostly a problem with the electronic steering wheel…
Old Aug 18, 2023 | 06:34 AM
SMac770's Avatar
Community Builder
If you have the electro-mechanical power steering (B8.5 started with MY13 according to the parts catalog; what is the actual 10th character in your VIN) and drove it into water, yeah, you probably trashed the J500. As you've seen, Audi doesn't do "repair". You need to still determine the actual source of the noise, if it's the J500 control module or the rack itself. The former would be common, the latter would be uncommon.
Old Aug 19, 2023 | 12:37 AM
Nikola998's Avatar
Yes, my car have electro-mechanical power steering.
I went to the mechanic and he said that sound coming from steering rack.
Is anyone know how to slove this? Maybe some lubrication or something?
I am interesting what is broken in steering rack?
Old Aug 19, 2023 | 04:50 AM
SMac770's Avatar
Community Builder
Probably not much you can do other than drop it and open it up and see what's what inside. It might be a mechanical issue with the rack, or it might be an electrical motor issue. The J500 is a control module and the power passes through it, but the actual motor that power assists the rack is in the rack.
Old Aug 22, 2023 | 04:47 AM
PEB60's Avatar
If there is an MIL set for the electro-mechanical steering there is a warranty extension. I frankly find it hard to believe that is what you have though. I would encourage a visit to the dealer to discuss the situation and what remedies might be available through VWA. You'll have to push to get them to cover anything other than than the specific parameters of the recall, but maybe you can a free diagnosis out of them for your trouble...
Old Aug 22, 2023 | 06:12 AM
SMac770's Avatar
Community Builder
He's not in the US.
 Pouria Savadkouei
 Michael S. Palmer
Old Aug 23, 2023 | 03:00 AM
Nikola998's Avatar
Thanks for replying everyone. I will try to put some lil or wd 40 in steering bar and see is that helping.
Jonathan V
27
Oct 13, 2023 09:50 AM
darius vinciunas
VAG-COM Discussion
Nov 5, 2021 12:33 AM
zaliah898
Aug 13, 2021 12:06 PM
ambeane
A4 (B9 Platform) Discussion
22
May 10, 2021 08:59 AM
biscjw
Q7 MK 1 Discussion
Jun 3, 2016 07:51 PM
