A4 (B9) - P011800 - Coolant Temperature Sensor
Hi folks,
Is this a common issue out there or I am just the 'lucky' one lol. Started the car today, fans started right away but did not think into it too much. As I drove away, I was looking at the temperature gauge and it suspiciously did not move at all even after about 10 minute drive while it was around +15C outside.
So read the codes with OBDEleven and got this code under Engine.
Has anyone seen this before and if so, is it something I can do myself with some basic tool and patience, or 'must take to dealer/repair shop' kind of issue. I imagine if the issue is this sensor, wondering how can I locate it and where I can source a good replacement part for it.
Thanks in advance everyone!
Hi everyone,
In the very unlikely case anyone sees this in the future, here is the verdict. Good news is that issue was found and corrected. Bad news is that it was found at Audi Dealer but oh well. See pic attached, a black wiring harness cut or ripped, this is the coolant temp sensor harness at the back of the motor under the headshield near the tranny case
Hi everyone,
Yes unfortunately
I got dealer to fix this a few weeks ago and guess what the issue is back.
Took this photo the other day when I changed the oil. All was well until today, started the car second time after sitting about one hour and exactly same fault again.
Is there any chance that bugger is still there somewhere? And what are the chances of cutting the same cable again??
This sucks big time.
Rodent nest?
Rodent nest?
I can tell you that the first step in assessing it would be to get that rat's next out of your engine bay! Then, I'd try and jack it up, drop the splashguards, and make sure there aren't any animals still there!
Vehicle has been parked outside for the past few weeks though (I'm in Bradford, ON), how the heck this is even possible for rodents to survive and also - why the same damn cable??
I did not think to drop the splashguards, so that's what I'll do very soon.
The one upside is that damage could have been way worse...
Hello! I have a 2018 2.0T Quattro A4. Having the same error code come up - I think I need to replace the sensor since mine came up while driving so likely not a rodent issue. Is it hard to get to it - where is it located exactly? Is it hard to swap the sensor out with a new one?
TYIA
TYIA
Audi in MA
03-22-2005 04:19 PM
9490s33990
04-04-2003 06:01 PM
absentme
10-10-2002 07:05 PM
