Automatic headlights stopped working
#11
A past BMW I owned would do this in low angle sunlight, winter AM and PM, as a safety feature to help others see you when the low angle sunlight reduces visibility due to glare.
idk if that's the case with your Audi though.
#12
I don’t expect it to be “perfect” or replace the human eye, BUT sorry, it can and should work as designed. It should tell the difference between bright daylight and dark/dusk, and make adjustments accordingly. The fact that other I’ve owned two other cars that has Auto headlights and works “perfectly” makes me know this is NOT “normal” functionality.
#13
#14
What at I was referring to are the Automatic Headlights function where it’s supposed to detect ambient light conditions and turn on/off your normal low beams headlights automatically at day/night. Mine happens to stay on indefinitely regardless of the light conditions, unless I manually disable the Auto Headlight feature.
#15
In all honesty, because you are making one out of it. Relax. Maybe yours is worse than any other one and needs to be fixed. It’s certainly possible. But what he is talking about is in FACT a well known issue with the sensors. I don’t think that i have had a car lately that didn’t have the problem to some extent.
#16
#17
Perhaps the windshield area where the light sensor is located is covered in salt/dirt? Try wiping the windshield from the OUTSIDE near the top-center where the rear-view mirror is attached. Can you report back if that fixes it?
#19
Hi. Thanks for the response. I think what you are referring to are the Auto High-Beams. My car also has this feature and works flawlessly, where at night, the High Beams go on automatically, and switches back to low beam headlights whenever it senses traffic or intersections- so as to not blind other drivers.
#20
Oh I see. Apologies for misunderstanding what you meant. I don’t think it’s that because right now the headlights are on indefinitely, regardless of time of day or brightness. It’s like the light sensor think it’s night time all the time. Also checked sensor was clean and not blocked in any way. I’m thinking it’s probably a faulty light sensor, but hopefully it’s something that can remedied with a factory software reset, and not a hardware replacement. I’ll see what the dealer says. Just a little frustrated with a 2 week old car. Thanks for the reply.
