B9 Manual Transmission Quattro Ultra woes.
Old 05-15-2024, 05:47 AM
  #41
Sjorge3442's Avatar
Originally Posted by Bobert
wait after reviewing ever bit of 5 minutes of footage, the drive shaft stoped for about 2 seconds twice and I was in comfort mode driving slow down a stright smooth road
Was the 5 min of driving done on a cold car? I wonder if the Ultra system doesn't stabilize until transmission temps are fully up to operating temps. Either way, if you still have those noises occurring, it needs to go back to the dealer
Old 05-15-2024, 09:25 AM
  #42
Bobert's Avatar
So my car is a 2018 and I'm at 85 k miles now. I had the ultra awd an diff fluids serviced around 70k miles and everything was good till recently when in 3rd gear I was getting pulsing or rythmic vibrations under light throttle 50 percent of the time. Now the vibrations are twice as bad 100 percent of the time in 2nd,3rd,4th,5th under almost any throttle and they replaced the awd unit with the controll module from what I saw looking at it yesterday filming. I'm thinking software needs to refreshed or possibly adaption done properly as 142 guy said. But I do not have e any dtc's
So I had drove the car home from work then took 30 mins to figure out how to mount the go pro... so it was up to temp but mabye still a little cold.
I did a little more filming and what i saw was no matter what when coming to a stop or taking off slow and accelerating, the drive shaft was spinning. Only when cruising at a constant speed did the drive shaft stop spinning for a little
Here is a YouTube video I uploaded of the longest I saw the drive shaft stop spinning
Old 05-15-2024, 11:00 AM
  #43
Sjorge3442's Avatar
Here is a link to a document from Audi that explains the AWD Ultra a bit more. Per the documentation here, (Starts at page 26) it shows that the car is probably NOT in FWD mode more often than most people would claim so I wouldn't get too caught up on the driveshaft not disengaging more. Id assume you'd see it disengage mostly on smooth, straight, flat highways with cruise control enabled.
You could probably test turning off ESC to see how that impacts things too.
LightningTruck (05-15-2024)
Old 05-30-2024, 01:07 PM
  #44
Bobert's Avatar
Did any of you guys feel ryrhmic/ pulsing vibration under acceleration before you replaced your awd clutch fluid. My car has been at the dealer 2 weeks now. They are now saying the transmission is bad. They supposedly worked with audi tech line. I still don't understand how I felt all the same symptoms as you guys but awd replacement only made it 2x worse.
Old 05-31-2024, 06:04 AM
  #45
Sjorge3442's Avatar
I dont recall any pulsing when I was having my issues originally. Is it pulsing like a clutch slip pulse? Im confused as to how the transmission could produce a pulsing feeling. Id think more along the lines of clutch/flywheel or something in the ultra clutch for that sort of feeling.
Old 05-31-2024, 06:24 AM
  #46
Bobert's Avatar
I was thinking it was the clutch and told the shop foreman that when i went for a 10 min test drive with him... he said that's not it because theres no indication of clutch slip and vibration disappeares when going full throttle. I agree with you, dosent make sence how it could be the transmission. I'm still thinking they diddent program the awd unit properly
LightningTruck (05-31-2024)
shawn18232
07-07-2009 07:23 AM
864q
11
10-20-2004 02:35 PM
Dustin A4
12-22-2001 08:04 AM
Benjamin MacRae
11-13-2001 03:24 PM
XCCESS
02-12-2001 10:53 PM
Quick Reply: B9 Manual Transmission Quattro Ultra woes.
