Coding MPH from Km/h for Virtual Cockpit
#21
Note that this for CANADIAN vehicles using the conversion the MMI conversion from Km/h to MPH (US vehicles would follow the same process to convert from MPH to Km/h)
CONFIRMED
Done using VCDS (HEX-V2)
17-INSTRUMENTS --> LONG CODING --> BYTE 1 --> BIT 1... UNCHECK 'dual_speedometer,yes'
BOTH the circular dial & center numbers are in MPH now
When 'View' is minimized, it appears ONLY as MPH now (not split as before)
CONFIRMED
#22
Where To Begin
Just bought 17’ Q7 Prestige SLine. It’s a Canadian Spec’d one as well and I’d love to figure this out. Can anyone give me a beginners guide to making this kind of change? Where do I start?
CONFIRMED
CONFIRMED
dreiter2 (04-23-2023)
#25
Hey @billm0066
Thanks for sharing that you were able to change the KPH with OBDelleven, did you need the 'Pro' package to do so? thanks!
#26
Virtual Cockpit KG to MGH
I talked to Audi in Canada this week. Was not able to resolved via Audi in US. Audi in Canada called me back today and said the issue was a bug and audi should have a software upgrade sometime later this year. I will call them in October 2021 and ask for an update. They said dealerships will then know how to handle.
#28
Just purchased a 2017 A4 Premium Plus in Canada, with the car being originally from California. Stumbled upon this thread because I was also experiencin this issue, changed everything over to KM/h, but the middle readout was in MPH. Saw the post claiming Audi Canada was hoping to have a fix by the end of last year, so I made an appointment at my local audi dealer to see what could be done. Long story short, Audi can't/won't do anything. Ended up buying an OBDEleven and running the long coding fix mentioned above. Worked like a treat! Thanks Audi World!
#29
2021 SQ5 from Canada
#30
Hi, I am in the same boat. I just got mine delivered in Ohio and is the opposite issue, I have KPH vs MPH. I just cannot find anywhere any directions of how to fix that. Do you know if a dealer will do it or I need to get the OBDEleven? Do you know if there is a video anywhere how to do it and which version of the OBDE to get? Any help is greatly appreciated. Thank you. Ivan
Once connected to your OBD11 app, you'll see different "modules" listed for each system. You goto 17, scroll to "instruments", select " long coding", 'byte 1", "bit 1" and then Uncheck"dual speedometer, yes".
And that's it!
Buy the cheapest obd11 that supports "long coding", I believe it was the "pro" version... But you're specifically looking for that "long coding" functionality.
