2016 S6 to replace my 2012 A6 3T - what to expect?
#31
When I had the PCV issue on my A6 I was burning a quart every 3K miles...After the fix, it went to about 1/3 of a qt every 6K miles. If I was burning a quart every 700 miles, I would make it my top priority to figure out why. that much oil loss doesnt seem like a PCV issue.....That is beyond the definition of excessive. consumption. Not sure why you want to ignore that.
#32
When I remove the oil filler cap with the engine running, there is some suction making removal a bit harder, but not a massive amount. Once removed, I can detect a different rpm. Is this normal? I seem to recall that removal of oil cap used to be more difficult with engine running.
#33
I believe some resistance is normal...If the PCV is bad it should be extremely hard to remove the cap during idle. The change in RPM/bog is normal as you are creating an air leak in the system...
If you are losing that much oil, do you see white smoke out the tailpipe?
#34
In addition to my A6 I have a Q5 with the same exact 3.0L. The Q has 100K miles and I never have to add oil, and my A6 has 172K, and as mentioned I add 1Qt every 700 miles or so. So I had them both running in my driveway, side by side. I removed the A6 oil cap with modest resistance from the suction. I then went to the Q, and It was significantly harder to where I almost needed a tool to remove it. So the oil cap theory is working opposite what I am hearing, as the Q has no issues I know of.
Thoughts???
#35
not sure....I just tried it on my 2012 3.0T A6 w/165K miles. cap was fairly easy to remove but could feel the suction. No known current PCV issue on the car, did have PCV replaced at 50K miles.
#36
Thanks for the tips, but now I am really confused.
Thoughts???
Thoughts???
I'd strongly suggest you get the car diagnosed by a professional vs. yourself and get this fixed, since you're leaking oil like a sieve and these things tend to only get worse.
doyletr
02-04-2016 06:58 PM
audi8times
10-08-2011 06:28 AM
