AU: Oil on spark plugs?
I made a thread a while back, though I now have had a bit of a breakthrough which really sums up the problem very differently.
I changed my PCV, Water Pump and Thermostat a while ago. Ever since doing it, my plugs have been fouling. I was sure it was fuel (probably because it made more sense), though today I can confirm it is oil.
It has been very weird and intermittent, although it has recently gotten worse. Initially, it was No. 3 Cylinder every single time. It has recently moved to being more No 1 and 2. It is only ever this bank, I have zero issues on the other. I am starting to consider some oil is getting sucked into the cylinder, which makes me think, perhaps my PCV is faulty. Has anyone ever heard of this? It is $350 for another one, would like some level of certainty before going that way.
Might be worth noting... The pipes that come from the PCV, going to the valve cover, have very little vacuum. The oil cap, has a lot less vacuum than it had just after I changed the PCV valve.
6 out of the 8 plugs in my 2008 A6 4.2 were soaked in oil and the issue was the valve cover gaskets, just learning more about the 3.0T motor as I just purchased a 2016 A6 3.0T so I dont know if that could be an issue with yours but food for thought I guess...LOL
An update... I just installed a new PCV, no help. The main problem cylinder was 3, every time, it was 3. Now it has moved to 1. What on earth is happening?!
Read this: https://www.audiworld.com/forums/a6-...3-2-a-2987300/
I think the lower valve cover gasket is non existent on the 3.0 TFSI. There would only be anaerobic sealant. Your camshaft guide frame (cam girdle) might need to be resealed.
I guess the following is what you needed to see. Watch the video from 3:33.
No oil on my coil packs or in the wells, it is definitely coming from inside the cylinder...
