Enabling unrestricted "Lane assist"
Old 03-06-2014, 09:24 AM
  #41
DeerHunter's Avatar
I was poking around the web today and found the following image:
Now, this is for the RS7, but the tech should be the same for all A/S/6/7. Doesn't it imply that the camera is involved with ACC and/or Pre-sense Plus?
Old 03-06-2014, 09:41 AM
  #42
gatorguy7's Avatar
The lane assist uses the camera but collision avoidance and ACC is through radar. The picture seems to be showing a combination so maybe it is meant to show both.
Old 03-06-2014, 09:52 AM
  #43
DeerHunter's Avatar
It states "object detection assistance and lane allocation on the basis of video data", implying that the camera helps with both functions. Furthermore, why would the system highlight other cars (blue boxes) if it was just for lane assistance? There's more capability in the system than we realize, methinks.
Old 03-06-2014, 10:10 AM
  #44
snagitseven's Avatar
I wouldn't assume this from that diagram's description. Read the detailed Audi US article link I included earlier in the thread. It specifically describes the ACC as radar (ACC and Braking Guard are components of Presense Front) and Lane Assist as camera/video actuated. ACC (and Brake Guard by extension) have a fairly narrow beam in order to only detect followed vehicles in the same lane as the car. This diagram shows a wide beam probably to include Lane Assist. The ACC/Braking Guard radar sensors are the round lenses in the lower grilles and do not contain cameras. The Lane Assist camera (if equipped) is located in the main grill next to the Audi emblem as I recall.
Also, keep in mind that ROW Audis have other systems that we don't get in the U.S. such as auto headlight beams which probably also use cameras or light sensors along with nav based lighting range.
Old 03-06-2014, 11:58 AM
  #45
DeerHunter's Avatar
It's official - the top-mounted camera (behind the rear-view mirror) is used with ACC and Predictive Emergency Braking (skip to 3:08):
Old 03-06-2014, 01:29 PM
  #46
Ok, I found the camera on my car. I'm eating my manual as I write this.
Mmmm. Tasty, but a bit dry.
Old 03-06-2014, 03:30 PM
  #47
jdong's Avatar
Haha, no worries
Unfortunately the camera on our Audis is a pretty simple setup. Not really as awesome as the stereoscopic cameras that are on the 2014 Mercedes S class which provide a 3D contour map and realtime tracking of every car in the field of vision, not unlike those sweet Kinect based projects.
I'm sure that's the basis of what's on Audi's self-driving A7 demos they've been showing off to the press. Once you have a system like that, you'll be able to use radar/laser to obtain accurate distance and speed info, and use a vision sensor to accurately associate what you're reading with what's in front of you.
Old 03-08-2014, 12:37 AM
  #48
JRomulus's Avatar
"or a hybrid of K-band radar and a sweeping LIDAR sensor"
Which explains why my radar detector beeps a lot more these days than a few years ago...
Old 08-06-2023, 03:24 PM
  #49
Darksidev8tt's Avatar
Lane Assist Activation - (will vary slightly on each model)
Select Control unit 17 (Dashboard)
Control unit Long Coding
Bye 4
Bit 6 Activate
Bye 11
Bit 1 Activate
Select Control unit A5 (front / advance camera)
Bye 0
Bit 0 Activate
Security access
Access Code 20103
Adaptation
Channel - Seçim HCA_On_State
Put emphasis on menu
Channel - Seçim HCA_Warning_intensity
Channel - Seçim BAP_Personalisierung
Put emphasis on not activated
Select the time of engagement
Set adjustment via menu - emphasis on late
Select Personalization spurt holding an assistant to a terminal 15 - channel
Set value to last setting
Select Control unit 44 (power steering)
Bye 0
Bit 0 Aktif
Select Control unit 5F (Informationselektronik)
Adaptation
(49) function -Vehicle list BAP LDW_HCA_0x19
Activate
(21) vehicle menu operation-menu_display_Lane_Departure_Warning
Activate
(23) vehicle menu Bedienung_menu_display_Lane_Departure_Warning_over _threshold_high – channel
Activate
jaims
Q5/SQ5 MKII Discussion
06-27-2018 12:41 PM
morecarsthanbrains
Audi allroad
9
11-21-2008 04:35 PM
Boston Driver
21
12-18-2007 12:08 PM
FSI Power
A4 (B7 Platform) Discussion
11-12-2005 02:04 PM
Boston Driver
VAG-COM Discussion
07-28-2005 01:06 PM
Quick Reply: Enabling unrestricted "Lane assist"
