Help with Brake/Rotor Replacement
Hi,
I have a 2013 Audi A6 Quattro Prestige with 20"Rims. it has 40,000 miles on it. The replace brake light just came on. Is there any way to find out from the sensor light if this is the front brakes or the rear brakes or both?
AIso I have a shop that can replace the brakes and allows me to buy the parts. Since it is recommended I was thinking of replacing both the pads and the rotors
Can someone recommend good quality (and budget friendly) brake pads and rotors that I can buy online. I found the following brake pads and rear rotors from Amazon, but have had no luck finding good and economical front rotors. Any advice would be great. Thanks.
Before you do anything, verify what is needed. The fronts are probably worn, but that light comes on very early.
Given that you don't really have a pad in mind or a good place to source them, why not just let the shop get them? There are tons of choices; figure out what your needs are and ask the shop to source (track use? live on top of a mountain? city driving? low dust? etc)
Normally on Amazon I am able to find the parts. This time there are not many choices on Amazon (Most have no reviews). I have never bought parts for Audi before. Is there another better source out there? also I was not sure if my Tire size (20") changes the size of the rotors I need?
Hi,
Rear Brakes
Rear Rotors.genuine
Front Brakes
Rear Brakes
Rear Rotors.genuine
Front Brakes
You might want to check the following websites for the parts you need; www.genuineaudiparts.com; www.audionlineparts.com; www.audipartssupply.com; and www.audiusaparts.com. Good hunting !
https://www.audionlineparts.com/auto...nt-brakes-scat
Thank you.
Rotor sizes by model/engine:
A6 2.0L - 13.6/13.0 (345/330 mm)
A6 3.0L - 14.0/13.0 (356/330 mm)
A6 TDI- 13.6/13.0 (345/330 mm)
S6 - 15.7/14.0 (400/356 mm)
Best thing is to use the PR code from the little square sticker in the trunk. I.e., my 2013 A6 2.0L is different than above post (things change year to year, etc.):
Front rotor(1LA): 320mm dia, 30mm thick new, 28mm min
Rear rotor(1KW): 300mm dia, 12mm thick new, 10mm min
Hi,
Centric Stop Tech makes good high carbon and coated rotors. Zimmerman is another name mentioned. Ceramic pads reduce brake dust on your wheels but they lack the initial bite of the OEM semi-metallic pads. You will need two wear sensors for the left side inner pads. Some pads include a sensor.
My used A7 has the ACC which uses the rear calipers to slow down. The previous owner used it and I found my rear pads had the most wear when I replaced them.
Curious regarding the sensor comment. I have a set of front Akebono Euro pads that came with 2 sensors. I have rear Akebono Euro that didn't come with a sensor. Are these sensors useable for both front and rear? They're identical and have no identifying information.
Also, any idea about using Centric Stop Tech rotors paired with Akebono. Many have mentioned using Zimmerman with Akebono. Don't know anything about Centric but am open to what rotors I will order in the next week or so. Price is probably similar I expect.
Thanks.
Thanks.
