left turn signal/brake light /rear light warning
Old 10-17-2018, 11:49 AM
1loveaudi's Avatar
Default left turn signal/brake light /rear light warning
I just started getting this a couple of weeks ago and it goes away sometime. Other times all the LED's work just fine. Does anyone else have this problem?
Old 10-17-2018, 12:19 PM
KevinGary's Avatar
I had the problem a couple of years ago. Audi replaced the entire light unit under warranty.
Old 10-17-2018, 04:37 PM
1loveaudi's Avatar
I hope I don't have to replace the whole assembly. That will cost allot of money. Maybe I can get one from a wrecked A6
Old 10-18-2018, 03:48 AM
KevinGary's Avatar
Since it was replaced under warranty I don’t know the cost. I would guess around $400.
Old 10-22-2018, 06:51 AM
1loveaudi's Avatar
I just took an hour and a half trip yesterday and the signal/brake light work just fine. No problems or warnings. I had the wife hit the brake and turn signals while I watched and everything is lighting up. Does anyone know the name of the control module that might be at fault? Maybe it's cheaper to replace than the light assembly.
Old 10-22-2018, 07:48 AM
KFPanda48's Avatar
I was having a similar issue. Now at this point my entire inner drivers side light is out except for when I signal and hit the brake. Shop here wants $400 ++ to replace the assembly. Following this also.
Old 11-19-2018, 07:51 AM
1loveaudi's Avatar
I did it myself with this OEM part from Amazon:
https://www.amazon.com/Valeo-44694-Driver-Light-Assembly/dp/B008BR6ZY4/ref=sr_1_2?ie=UTF8&qid=1542646087&sr=8-2&keywords=Valeo+44694 https://www.amazon.com/Valeo-44694-Driver-Light-Assembly/dp/B008BR6ZY4/ref=sr_1_2?ie=UTF8&qid=1542646087&sr=8-2&keywords=Valeo+44694
It only took about 10 minutes. This part had all the same stickers, number and marking as the one I removed.
KickAss (10-20-2021)
Old 05-06-2019, 08:33 AM
jeff kong's Avatar
Default Left turn light/brake light warning
just open the cover of the left side of the light then unplug and plug in again the connectors ! Problem should be solved!
Old 06-24-2022, 06:21 AM
Dutch29's Avatar
Does this really work? I have seen no responses.
Andrew Lewis
Audi A3 / S3 / RS 3
06-28-2022 12:11 PM
rxpclb
10-20-2021 12:17 PM
wrightd223
04-11-2017 08:59 AM
Matt0987
11-30-2014 06:56 PM
A4tek
02-07-2007 04:56 PM
Quick Reply: left turn signal/brake light /rear light warning
