Need help with some issues with my car
Hello there,
ran my just acquired vcds on my A6 C7 a few times and on the last scan after clearing the faults code a few times I've got the following remaining faults codes:
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 28 36 3B 42 44 46 52 53 55
56 5F 62 6C 72 85 8F 90
VIN: WAUZZZ4G9BN031310 Mileage: 165872km-103068miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
3B-Sensor Elect. -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
85-On Board Cam. -- Status: OK 0000
8F-Pretens. Frt Left -- Status: OK 0000
90-Pretens. Frt Right -- Status: OK 0000
Address 01: Engine (J623-CGWB) Labels:. 06E-907-551-CGW.clb
Part No SW: 4G0 907 551 HW: 4H0 907 551
Component: 3.0l V6 TFSI H05 0007
Revision: --H05---
Coding: 0A250034052701020000
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_ECM30TFS0214G0907551 002010
ROD: EV_ECM30TFS0214G0907551_002.rod
VCID: 6695B5FFE8EFBBD753B-8032
1 Fault Found:
6368 - Bank 2: CMP Sens 2 (G163) / Engine Speed Sensor (G28)
P0018 00 [039] - Incorrect Correlation
Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 1
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:33
Engine speed: 690.00 /min
Normed load value: 22.0 %
Vehicle speed: 0 km/h
Coolant temperature: 93 °C
Intake air temperature: 76 °C
Ambient air pressure: 980 mbar
Voltage terminal 30: 13.304 V
Unlearning counter according OBD: 40
Engine speed: actual: 672 /min
MAF_ENVD: 136.17647 mg/stroke
Calculated oil temperature: 85
Engine: operating status: IS
ENVD_CAM_IN_2: 0
Battery voltage: 13.507813 V
Readiness: 0110 0001
Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
Part No SW: 4G0 927 156 M HW: 0B5 927 156 F
Component: 0B5 30TFSIRdW H10 0024
Revision: --H10--- Serial number: 0000000785
Coding: 000001
Shop #: WSC 04940 001 00001
ASAM Dataset: EV_TCMDL501 A02196
ROD: EV_TCMDL501.rod
VCID: 363525BFF8CF0B5723B-8062
No fault code found.
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 HW: 4G0 907 379
Component: ESP PREMIUM H08 0190
Revision: -------- Serial number: --------------
Coding: 44A687002265E100DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 003013
ROD: EV_ESPPremiAU57X_003.rod
VCID: 6E85CDDFC01F73972BB-803A
Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AP HW: 4H0 907 064 AP
Component: BCM2 2.0 H24 0217
Revision: 00002001
Coding: 05B82F00000000000000
VCID: 77ABE8BBBFC5325FF8D-8022
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Serial number: 2311000097450009
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
Part No SW: 4G0 820 043 K HW: 4G0 820 043 K
Component: KLIMA 4 ZONEN H11 0056
Serial number: 06051100040574
Coding: 6621007824
ASAM Dataset: EV_AirCondiComfoUDS 002029
ROD: EV_AirCondiComfoUDS_002.rod
VCID: 270BF8FB2F6562DFA8D-8072
Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 N HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0092
Revision: 20012002 Serial number: 00000001044197
Coding: 0200201050B49FE0C181008380001908CF9DC3082F08010100 0008402100
VCID: 33331CABEB3D1E7F045-8066
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 110404 H35 0051
Serial number: 110407090850
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11418017
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 E HW: 4G0 941 531 E
Component: E1 - LDS H07 0044
Serial number: 22 04 2011 00000235
Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Component: AQ_Hum_Sensor H02 0002
Serial number: 5228C6A5000000000001
1 Fault Found:
01771 - Control Module for Headlight Range (J431)
013 - Check DTC Memory
Freeze Frame:
Fault Status: 01101101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Time Indication: 0
Date: 2019.11.07
Time: 11:00:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 J HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0032
Revision: 11001001 Serial number: 55901107004778
Coding: 300306
Shop #: WSC 00097 210 98728
ASAM Dataset: EV_EPHVA18AU57X0000 001002
ROD: EV_EPHVA18AU57X0000_001.rod
VCID: 392F2E83C9D1E42FCE9-806C
Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG002BRPH
Coding: 30323436313330303631554A305234473053
ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
ROD: EV_AirbaAU10BPAAU64X_VW51.rod
Crash sensor for side airbag: driver side:
Serial number: 3575HRB404T0HM766GDR
Crash sensor for side airbag: front passenger side:
Serial number: 3585HRB405H0H0LUC8R2
Crash sensor for side airbag: rear: driver side:
Serial number: 3515JRB405D0H4DU9P4N
Crash sensor for side airbag: rear: passenger side:
Serial number: 3525JRB405F0G944N0G$
Crash sensor for front airbag: driver side:
Serial number: 3554VRB40630GR36HOS5
Crash sensor for front airbag: front passenger side:
Serial number: 3564VRB405D0GR36IHD.
Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20110505000939
Coding: 000034
VCID: 303913A71A2B2567797-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H07 0009
Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
Part No SW: 4G8 920 981 A HW: 4G8 920 981 A
Component: TBenGb H34 0312
Revision: 19100074 Serial number: 658020411593026
Coding: 33A709000B012600010000
ASAM Dataset: EV_RBD4K 004033
ROD: EV_RBD4K_AU57.rod
VCID: 313F16A311A12C6F769-8064
Address 19: CAN Gateway (J533) Labels:* None
Part No SW: 4G0 907 468 C HW: 4G0 907 468 A
Component: J533--Gateway H08 0204
Revision: -------- Serial number: 00000000141378
Coding: 00CD073000
ASAM Dataset: EV_GatewUDS 001025
ROD: EV_GatewUDS_AU57.rod
VCID: 303913A71AAB2567797-8064
Battery Monitoring Control Module:
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005650387009
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 11130001538021200181
Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
Part No SW: 4G0 919 158 C HW: 4G0 919 158 C
Component: KLIMA FOND H07 0056
Serial number: 06051100040012
Coding: 02
ASAM Dataset: EV_ClimaContrUnitRearUDS 002012
ROD: EV_ClimaContrUnitRearUDS_002.rod
VCID: 2F3B10DB07953A9F60D-807A
1 Fault Found:
0026 - Motor for Rear Left Upper Body Vent
B10D3 21 [009] - Signal Amplitude Too Low
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:26
Voltage terminal 30: 14.04 V
Outside air temperature: 38.5 °C
Left Rear Upper Body Vent Motor-Act.val.: 10812
Left Rear Upper Body Vent Motor-Specified value: 10812
Left Rear Upper Body Vent Motor-Stop open: 11400
Left Rear Upper Body Vent Motor-Stop closed: 10000
Address 36: Seat Mem. Drvr (J136) Labels: None
Part No SW: 4G8 959 760 HW: 4G8 959 760
Component: MEM-FS H03 0153
Revision: AA000000 Serial number: 00000006129999
Coding: 00781B0000006001000001010101102030303232203232
Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
Part No SW: 4G0 907 637 B HW: 4G0 907 637 B
Component: SARA 6D H02 0004
Revision: -------- Serial number: EJ1BPA4200UA850
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 2D070AD30D99488F521-8078
Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
Part No SW: 4G8 959 793 C HW: 4G8 959 793 A
Component: TSG FA H04 0210
Coding: 011F16205E01628002080002
Shop #: WSC 02312 785 00200
VCID: 40D94367AA8BB5E7897-8014
Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H33 0010
Revision: 00001000 Serial number: 0010073316
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323D19AF14A717770F3-8066
Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0149428872
Coding: 011B0E2200B904818330080408010000000000000000000000 0000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
1 Fault Found:
01134 - Alarm Horn (H12)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Time Indication: 0
Date: 2019.11.07
Time: 11:00:28
Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
Part No SW: 4G8 959 792 C HW: 4G8 959 792 A
Component: TSG BF H04 0210
VCID: 3FDB409BD775CA1FF0D-806A
Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000070722
ASAM Dataset: EV_ParkiBrake 001022
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0D01CF3C775FB7B73-807E
Address 55: Headlight Range (J431) Labels:| 4H4-907-357-V1.clb
Part No SW: 4H4 907 357 A HW: 4H4 907 357 A
Component: ....AFS13.... H01 0012
Serial number: 110502-0004-033
Coding: 1121A633F918EB00
ASAM Dataset: EV_AdvanFrontSyste 005001
ROD: EV_AdvanFrontSyste_AU21.rod
Left Headlamp Power Output Stage:
H02 0008
Coding: 1D0000
Right Headlamp Power Output Stage:
H02 0008
Coding: 1D0000
1 Fault Found:
0061 - Function Restriction due to Implausible Message(s)
U1112 00 [137] - -
[Fehlerhafter DLC der CAN-Messages Kamera_Status (0x318)]
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:30
Address 56: Radio (R) Labels: Redir Fail!
Part No SW: 4G0 035 056 A HW: 4G0 035 056
Component: Radio U STD H52 0050
Revision: AB001007 Serial number: 051EY0B7516476
Coding: 010003020100000001
VCID: 1F1BE01B77B5AA1FD0D-804A
Address 5F: Information Electr. (J794) Labels:. 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 B HW: 4G0 035 670
Component: H-BNT-EU H46 0239
Revision: -------- Serial number: 428EX0B7514227
Coding: 050101000003E1EF45108B3E000000030000010000000000
VCID: 221DE9EF44C787F7FF3-8076
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1300QPJ1
Subsystem 3 - Part No SW: 4G2 919 612 L HW: 4G2 919 612 L
Component: E380 BDT C7 H08 0120
Serial number: 90349KDT0007U
Subsystem 4 - Part No: 8R0 060 961 A
Component: CD-Database 2712
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4G8 959 795 C HW: 4G8 959 795 A
Component: TSG HL H03 0210
Coding: 010F14204001628002080002
VCID: 42DD496FA487A7F79F3-8016
Address 6C: Back-up Cam. Labels: 4H0-907-441.clb
Part No SW: 4G0 907 441 A HW: 4H0 907 441
Component: SG Rueckfahrkamera 0050
Revision: --H04--- Serial number: 525 PA8J14F0S1
Coding: 1020004
VCID: 2517F2F359E970CF9A1-8070
Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
Component: TSG HR H03 0210
Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
Part No SW: 4G0 907 217 HW: 4H0 907 217 A
Component: DPC-SG H24 0034
Revision: -------- Serial number: 262130025421000
Coding: 64040000
ASAM Dataset: EV_OnBoardCamerDPC 001007
ROD: EV_OnBoardCamerDPC.rod
VCID: 6597B2F315E9B0CF5A1-8030
Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 945 HW: 4H0 980 945
Component: RGS-VL H05 0070
Coding: 00060000031F030000030800424CDA010000
ASAM Dataset: EV_RGS_L 002004
ROD: EV_RGS_L.rod
VCID: 6FBBD0DBC7157A9F20D-803A
Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
Part No SW: 4H0 980 946 HW: 4H0 980 946
Component: RGS-VR H05 0070
ASAM Dataset: EV_RGS_R 002004
ROD: EV_RGS_R.rod
VCID: 70B9D3A7DA2B6567397-8024
End----------(Elapsed Time: 02:06, VBatt start/end: 14.2V/14.0V)-----------
My questions are:
1. for address 01, whether I need to replace the Bank 2 camshaft position sensor to clear the fault codes?
2. fault codes for address 09 and address 55 are about headlight range and seem related, what should I do? As for this issue the yellow adaptive light indicator on the instrument cluster is lit.
3. for address 28 and 46?
Appreciate you suggestion and help. Thank you all in advance.
Regards
Revision: --H05---
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:33
ENVD_CAM_IN_2: 0
Coding: 000001
Revision: 00002001
Coding: 6621007824
Coding: 0045F7
Coding: 02512B
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Time Indication: 0
Date: 2019.11.07
Time: 11:00:00
Coding: 300306
Coding: 000034
Coding: 00CD073000
Voltage stabilizer:
Coding: 02
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:26
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Time Indication: 0
Date: 2019.11.07
Time: 11:00:28
H02 0008
Coding: 1D0000
H02 0008
Coding: 1D0000
1 Fault Found:
U1112 00 [137] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 243
Mileage: 165872 km
Date: 2019.11.07
Time: 11:00:30
Coding: 1020004
Coding: 64040000
ROD: EV_RGS_L.rod
ROD: EV_RGS_R.rod
My questions are:
Regards
Danielfive5
06-12-2019 11:04 AM
Chintan Bhatt
A4 (B8 Platform) Discussion
10-31-2016 06:45 PM
johnnytyler24
VAG-COM Discussion
11-30-2014 09:54 AM
