P179D - Electrical Malfunction
Code:
Thursday,29,March,2018,22:20:39:25423 VCDS Version: Release 18.2.0 Running on Windows 10 x86 www.Ross-Tech.com Address 02: Auto Trans Labels: 0B5-927-156.clb Control Module Part Number: 4G1 927 156 B HW: 0B5 927 156 F Component and/or Version: 0B5 30 TDIRdW H10 0002 Software Coding: 000001 Work Shop Code: WSC 02311 785 00200 ASAM Dataset: EV_TCMDL501 A02087 (AU57) ROD: EV_TCMDL501.rod VCID: 2C57548A4768782494-8078 1 Fault Found: 8030 - Cooling Oil Valve P179D 00 [036] - Electrical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 40 Mileage: 111825 km Date: 2018.03.29 Time: 21:27:30 Engine speed: 1390 /min Transmission input speed: 1390 /min Transmission output speed: 346 /min Engine torque: 76 Nm Transmission fluid temperature: 52 °C Accelerator position: 18.0 % Clutch status: Kupplung 2 kann Moment übertragen
Thanks
I remember that Steve (IKnowHuhA6) had a problem with an electrical connection. Look through his thread - lots of info and some may apply to your problem.
https://www.audiworld.com/forums/a6-...nyone-2886141/
Yes I have looked at his thread. His error code is different to mine. Not sure if cure is same. Lets see as I have booked my vehicle with transmission specialist for next week.
Had my car with transmission specialist yesterday. They advised electro plate kit and transmission cooling solenoid needs replacing at the cost of £1100 + VAT. I asked them to break down the cost for parts and labour so I know what I am paying for but they refused to give the price and said if I supply the parts they won't do the job.
Seems like I need to look elsewhere or bite the bullet and go with the quote.
