Sound system/phone problem and solution found
Here's a solution to a problem that might help someone else...
Today my sound system suddenly started going south. Every time after I turn on the car (or reboot the MMI) after 15 seconds or so all radios and media sources would go silent. When I selected any source, the station or song could not be changed in the MMI on radio or media device and the telephone module showed a call was in progress, even though it wasn't and the MMI "end call" button did nothing when selected. No directories from my phone and the voice control is dead. (Interestingly, the nav voice guidance seemed to still work).
So, the call in progress thing gave me an idea - I thought that the MMI and phone connection had something to do with the issue. First, I turned off the bluetooth on my iPhone. All the music and operation came back confirming this. So, next I tried deleting the bluetooth devices in both the phone and MMI. After reestablishing and re-pairing a new bluetooth connection, the same problems returned. So long as the phone was connected, the MMI thought I was on a call and no music. Strangely, selecting a different song or source was still frozen on the MMI screen.
Next step to try was to delete the bluetooth phone device profiles again on both the car and the phone and do a hard reboot of the iPhone. Re paired the bluetooth devices and problems solved. All worked normally again, sound and song selection on all sources.
Take-aways? If you have experience any weird issues with your MMI operation, first try rebooting the MMI (do the three-fingered press of the MENU+selector control+upper right function button). Next is to reboot any connected devices. Chances may be good that one or both went into some kind of a gonzo connection state that a simple reboot of either or both will correct.
Here's a solution to a problem that might help someone else...... If you have experience any weird issues with your MMI operation, first try rebooting the MMI (do the three-fingered press of the MENU+selector control+upper right function button). Next is to reboot any connected devices. Chances may be good that one or both went into some kind of a gonzo connection state that a simple reboot of either or both will correct.
d0nut s4
02-11-2016 04:48 AM
Quetzal
Wheels & Tires Discussion
09-23-2015 07:50 PM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
