Stabilisation program, lane assist, TPMS, gearbox, parking brake,headlight range ctrl
Hi
My Audi A6 Avant 2012 2.0 TDI won't start randomly and gives me a lot of faults. So sometimes, when I start my car, these faults appear in this order:
Stabilistation program fault! see owners manual
Audi active lane assist: currently unavailable
TPMS tyre pressure: system fault!
Gearbox malfunction: you can continue driving
Parking brake!
Headlight range control: system fault
When I turn off the ignition and wait for a while, the engine starts normally except for a start-stop failure fault. Now when I turn off the engine and turn it on again, all faults are gone and the car works normally for a few days until it does the same again.
I took my car to a dealer, who read the codes and reseted them. They said that they didn't find any faults after resetting and they checked the ABS-sensors which were all fine. I got a print on paper of the faults they read. It was 200 euros for apparently nothing...
Any ideas what could be the problem?
Parking brake!
Touy19901990 (05-01-2022)
An electrical relay was broken in the ECU. When I tried to start the engine with the fault on, I wiggled all the relays in the ECU until the engine started. That's how I found the broken relay. The relay was cheap to change.
We've located relay 645, opened it and found out it was faulty. We repaired it and now everything is back to normal.
Thank you for your help - we would have never figured it out on our own due to misleading errors in VCDS.
Norrbaggen (02-14-2022)
I am currently experiencing almost the same problem
stabilizing malfunction , hill hold assist fault and parking brake fault
it does that after about 20 minutes of drive and it disengage the gear
diagnosing machine showed error U010100 lost communication with TCM
could it be the same relay
Danial (12-21-2021)
I have the exact same issue on mine 14 plate A6 and the electrician was blaming battery.. Changed the battery and no luck!
After driving for 30/40 mins this came back
We have tried the Abs wheel sensors and they are still good so I don't know where is the problem
Hi Anej.
I have a Audi A6 Avant 2016, is that the same car you have?
I also have all this warnings coming up
-Brake servo restricted
-Headlight range control system fault
-Parking brake fault
-TPMS Tyre pressure system fault
-Stabiliisation control (ESC/ABS): fault
Was all this because of relay 645
