Vagged my car and some observations
#11
Isn't supercharger boost available at low RPM? Unlike turbocharger where boost will kick in at higher RPM. At 3000RPM, i did not see any color light up in the boost gage.
#12
My observations are about the same:
1) Downshifts are slower and the car maintains more momentum when you let go of the gas.
2) Steering response is a bit heavier than comfort but lighter than dynamic.
In terms of actual efficiency I'm not picking up any major differences. I drive a ~36km route of about 25km highway/7km Medium speed roads late at night regularly (no traffic and temperature has been consistent for the last couple of weeks) and I've been hitting anywhere between ~7.5L/100km (31MPG) to ~8.4L/100km (28MPG) between both comfort and efficiency. So its really hard to tell if it makes any major difference.
#13
Thanks.
#14
The problem with the boost gauge in the Lap Timer screen is that there are no units to indicate what exactly is being shown. I suspect that, in order to avoid it dancing around at part throttle, it's set to only show boost above a pre-determined threshold.
#15
I haven't try it while the car is moving. However, I did see E1-> S1 when I tapped the shift lever at a stop and the car shift as if in dynamic mode until tapping the shift lever again.
#16
#19
After much research, i believe efficiency mode is designed for TDI, not for gas version of the A6. Unless someone with gas version of the A6 can confirm efficiency came default with Drive Select.
#20
hmmm...
I enabled lap timer, I even went back in and verified the bit is in fact set.
But scrolling through all the menus I do not see a boost gauge (or a lap timer)
EDIT: never mind, I found it
r1100rider
A6 (C7 Platform) Discussion
14
11-19-2011 09:23 PM
bugbbq
01-11-2001 12:49 PM
