A6 (C8 Platform) Discussion Discussion forum for the C8 Audi A6 produced from 2018
Start/Stop Button Replacement
Old Sep 10, 2022 | 08:40 AM
Dutch K's Avatar
Default Start/Stop Button Replacement
new to me 2019 A6 (C8) 55 S-Line -- I purchased the red start/stop button from Europrice and have gotten all the way to removal of the old button (not quite so simple as in the C7) but cannot seem to dislodge it. Do I push down on it? or press up from the bottom? Do I need to turn it? thanks in advance for any help.
Old Sep 11, 2022 | 03:16 AM
DadAudi's Avatar
Subscribed as I would like to see more of this…
Old Sep 11, 2022 | 04:56 AM
Dutch K's Avatar
Default start/Stop Switch Replacement
figured it out one needs to remove the entire center console including the bottom climate control MMI screen (this is relatively straightforward removal (gear shift, side bolsters a few screws and electrical connections and the antenna connection on the center console) as its a single piece) and (very) carefully place on a work space upside down and remove the row that has the start/stop switch from the center console but removing the two (or so) screws holding it to the console -- unplug the switch from the bottom and the with row should drop down allowing access to the switch you should be able to prise it out there are three tabs (which you can see on the replacement) that need to be released. after iI sorted it the biggest concern was not scratching or breaking the MMI screen --- replacement is opposite.
Old Sep 11, 2022 | 06:10 AM
DadAudi's Avatar
Great, looking forward to seeing completed photo please.
Markhodges78
14
Aug 17, 2021 06:28 PM
tuna138
Dec 5, 2013 11:41 AM
triplecore
Jun 15, 2009 07:14 PM
DirtyVegasTT
11
Mar 16, 2009 08:11 PM
Nitin
12
Feb 21, 2009 08:44 AM
