2003 6MT A6 Quattro wont shift into reverse! And clutch issues.
Just baught this car I absolutely love it! But just today i couldnt get it to shift into reverse.. i pushed down on the shifter, to the left then up and it just wont go in. It dosnt grind but does make a little clicking noise like its hitting something. All the other gears seem to have no issues. Could this be my linkage of selecter fork? Also, when I push the clutch in all the way it sticks and makes a rattling/clicking sound when you keep it forced to the floor. It dosnt have any issues getting stuck untill its about 85% of the way in. Im thinking slave/master cylinders? Please help I realy want to get this car working right, its such a fun car to drive.
Update:
Now the car is shifting fine (i havnt done anything different). But the clutch is still making a rattling noise when pushed in all the way. And it still sticks.
Maybe the shifter linkage is the problem. You can check this out by pulling the console. Re clutch, I think the release/throw-out bearing might be bad or maybe broken spring on clutch disk rattling. You might get lucky on trans, but time for a new clutch assembly. You're going to have to drop the trans, so have a pro check it out. You don't want to go the expense and work of replacing the clutch without making sure the trans is OK.
CoolMax91
03-11-2002 12:54 PM
