4.2 Overheating
Old Jun 21, 2001 | 05:34 PM
quattroconvert's Avatar
New Member
Default 4.2 Overheating
Got the "overheat" warning in heavy DC traffic, 98 degrees outside. Believe me, you can't miss the warning - the full display lights up with the red thermometer and graphics. I was able to pull over immediately and shut the engine down, so hopefully no harm done. One interesting feature, the computer shuts the A/C down as you approach an overheat condition. There is no problem with cooling at speed (engine temp. gauge at midpoint, oil at 200 degrees), just at idle and stop and go in traffic. I think it may be the engine fan clutch or the supplemental electric fan or control module for one or both. I should find out soon from the dealer.
Any of you 2.7/4.2 owners experience a similar problem?
Old Jun 21, 2001 | 06:04 PM
April's Avatar
AudiWorld Uber User
Could also be thermostat stuck.
Old Jun 21, 2001 | 08:50 PM
brian 4.2's Avatar
Default Re: 4.2 Overheating
I ran my car hard at the track in the desert, 1/2 hour on 1/2 off for 7 hours. The air temp was over 100. The gauge would get to 250. The general consesus there was to let the car run at idle after the track time to let the car "cool down'. The engine temp would drop to 230 or so with the hood open in about 15 minutes. Just my 2 cents but I would suspect somethings not quite right.
Old Jun 24, 2001 | 08:23 PM
New Member
Turns out it was the control module for the supplemental electric fan. Now it stays locked on at dead center on the coolant temperature gauge and 200 degrees or below on oil temperature (Mobil 1 0W30)-- I haven't had the chance to put in any track time (sometime in the future...).
Thanks for the replies.
odoboyusa
Apr 23, 2006 06:00 PM
dan-needabimma
Jan 20, 2006 06:16 AM
Ede's 12v90
12v V6 Discussion
Jan 6, 2004 04:50 PM
easTT bay ray
Jun 12, 2002 03:37 PM
hsjb
Jul 30, 2001 03:44 AM
