B5 S4 downpipes on A6/ B5 S4 BBK on A6 possible???
The downpipes I'm not sure about. Anybody ever do it?
The BBK from what I know should be okay (it's a 332mm kit I'm looking at). Anything to look out for?
S4 downpipes are different - the left & right sides have different length pipes coming out of
the cats to go the cat-back, whereas the A6 downpipes are equal length where they tie into the cat-back.
If you can get a great deal on S4 downpipes it might be worth having an exhaust shop weld up the proper tubing length, though.
Also be aware that tip downpipes are different from 6-speed versions, I believe to clear the bulkier tip transmission.
I put the S4 piggie's on mine, the driver's side needed to get trimmed down a little. just make sure
they're from the same transmission set-up...6-speed to 6-speed. If I remeber right the S4 pipes were also a little larger diameter then the A6 ones...
reded427
04-16-2013 06:07 PM
Small Town Terrorist
Audi allroad
03-03-2008 04:47 PM
VR_Life
03-23-2007 05:40 AM
tybmw
05-08-2005 11:08 AM
